HA Container - Prerequisite libseccomp library
Hello ,
I am currenty installing a Debian 11 + Docker in order then to use HA Container based on the HA doc … Generic x86-64 - Home Assistant
In this doc , it is written
 Prerequisites
This guide assumes that you already have an operating system setup and a container runtime installed (like Docker).
If you are using Docker then you need to be on at least version 19.03.9, ideally an even higher version, and libseccomp 2.4.2 or newer.
I cannot found how to install this libseccomp library as it is missing in debian 11.
Please advice ?
Thank you
