skyshino
(Skyshino)
1
The link will update later.
This addon include several web pages, each of page provide a way to configure HA. It is designed to improve the efficiency of configuring HA.
At this version, the tool only include the following pages:
skyshino
(Skyshino)
2
ha-copilat addon: improve the HA configuration efficiency
- Device properity edit pages: change the area and label of device.
- YAML Edit pages: edit automation YAML script.
Read the full add-on documentation
Installation
The installation of this add-on is pretty straightforward and not different in comparison to installing any other Home Assistant add-on.
- Click the Home Assistant My button below to add the repository to your Home Assistant instance’s addon shop.
- Find the “ha-copilot” add-on in the Home Assistant add-on store and click it.
- Click the “Install” button to install the add-on.
- Start the “Example” add-on.
- Check the logs of the “Example” add-on to see it in action.
This is the addon configuration pages:
