HA Core 2025.10.2 Update: YAML Editor Syntax Highlighting Missing - How to get it back?
Note that I have the Home Assistant Green running Home Assistant Core (Home Assistant OS). After updating Home Assistant Core to version “2025.10.2” that came out today, I noticed that the YAML editor in both the “Automation editor” and “Dashboard editor” no longer displays syntax highlighting, indentation colours, or different colours for comments/values. Everything appears as plain white text.
  • I have tried refreshing the browser (Ctrl+Shift+R) and clearing the cache, but the issue persists.
  • Previously, in all versions that I have had including “2025.10.1”, syntax highlighting worked correctly.
  • Functionality of automations and dashboards seems unaffected; it is purely a visual/UI issue.
  • This affects both automations I am editing and YAML views in dashboards.
“Question / Request:”
  • Am I doing something wrong and can I do anything to get it working right?
  • Is this a known issue in 2025.10.2? Will it be fixed in an upcoming patch?
  • Is there a recommended workaround in the meantime?
Thank you for looking into this!
Definitely a new glitch, seeing the same!
Open issues already
Hello! I’m experiencing the same problem!
Same for me
What is weird is I have two instances, and updating both, it only happens in one. So it is like there is an incompatiblity with any custom component or so.
I experienced the same problem.
I hope this will be fixed soon :wink:
A fix is scheduled for Friday from my understanding…
Thanks, see the same and also shortcut for searching stops working
Great it’s fixed quickly :slight_smile:
It is still happening after update 2025.10.3
Edit: Now is fixed, after 2 reboots and some time, not sure why
FWIW, yesterday’s update fixed the issue on my system (HA Green unit)
Did you clear your browser cache after the update?
