HA Core 2025.11.0 - Cannot delete old backups
This appears to be a new issue: I can no longer delete old backups from HA under Core 2025.11.0
I display the list of “My Backups”, then click on the three dots next to the backup I wish to delete, then select ‘Delete’ from the drop-down menu, and…nothing happens. No verification dialog box and no deletion.
Any ideas why this is happening now?
Thanks!
For anyone else running into this (!and panicking!), here is a thread on Github stating a fix is in the works for the next release (after 2025.11.1) and some work arounds:
Looks like there wasnt a fix yet in 2005.11.1
The only way to delete a backup is to press multiselect, then select one backup and click delete in the red icon up.
Was facing the same issue. Came here and got satisfied. Multiselection is the answer. Only if you want to delete just one backup.
Thank you!
J’ai aussi ce meme problème de suppression de sauvegarde locale comme distante avec ma version ha 2025.11.2 , pour la restauration aucun problème mais le bouton supprimé n’a pas d’effet
Its a bug.
Choose multiselect, then choose the one you want to delete and then top right the icon for delete.
