2025.10.4 to 2025.11.0
It just runs then doesn’t work. Thsi is what I’m seeing in supervisor logs: (HAOS install straight on NUC with oodles of space)
2025-11-06 17:26:33.246 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-2034' coro=<DockerInterface.install.<locals>.process_pull_image_log() done, defined at /usr/src/supervisor/supervisor/docker/interface.py:404> exception=TypeError("unsupported operand type(s) for +=: 'int' and 'NoneType'")>
File "/usr/src/supervisor/supervisor/docker/interface.py", line 406, in process_pull_image_log
self._process_pull_image_log(curr_job_id, reference)
File "/usr/src/supervisor/supervisor/docker/interface.py", line 345, in _process_pull_image_log
total += job.extra["total"]
TypeError: unsupported operand type(s) for +=: 'int' and 'NoneType'
2025-11-06 17:26:33.256 ERROR (SyncWorker_2) [supervisor.docker.manager] failed to register layer: archive/tar: invalid tar header
2025-11-06 17:26:33.257 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-06 17:26:33.258 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
2025-11-06 17:27:49.046 WARNING (MainThread) [supervisor.addons.options] Unknown option 'mqtt' for Zigbee2MQTT (45df7312_zigbee2mqtt)"
