HA crash upgrading to 0.34 from 0.33
So I recently tried to update to 0.34.4 from 0.33.4 and HA will not load at all. It was working for the most part before, but now nothing. And my error log is riddled with this about everywhere (but changing media_player for whatever isn’t working)
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/media_player/__init__.py", line 20, in <module>
    from homeassistant.components.http import HomeAssistantView, KEY_AUTHENTICATED
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/http/__init__.py", line 17, in <module>
    from aiohttp.web_exceptions import HTTPUnauthorized, HTTPMovedPermanently
ImportError: cannot import name 'HTTPUnauthorized'
I don’t think this is the same problem as the websocket problem, but I could be wrong. Here is my git for my HA: https://github.com/kflinderman/Home-Assistant
I do not have a solution for your problem,
But i should remove the .conf files from your github.
@kflinderman
You can try
$ pip install aiohttp
