HA crashed after SD-Card was full and a reboot
Hi folks!
I use Ha since around 1 Year without mayor Problems.
Last Week i got the Message that my SD-Card Space is 0.0GB. To solve this, i deleted old backups, addons that i dont use anymore and tried some other stuff.
Today i changed the IP in one Device-tracker and rebooted the Pi. After the Reload Command i left the House for ~1h. After i was back a my flat, the HA was not active, but ping was working. I tried to connect with SSH with no luck (wrong password… but im pretty sure that i entered the right one…)
After the failed SSH, i conneced with a monitor and a keyboard to the Pi. To do this i needed to shutdown the Pi with the Powerbutton and move it to my office.
After checking the startup till the bluetooth helper, some message apears and the Pi rebooted. The reboot was to fast for checking the last Message.
I unpluged it again, because it was in a bootloop. After this i checked the SD-Card with the Tool “Linux file systems for windows” from paragon software. I mounted the SD-Card without any problems. As i wrote bevor, the SD-Card was full. So i deleted some old logs and the last Backup (saved it to my PC) unmounted the SD-Card and used the buildin check-tool in the Linux-tool. I got a Error back that the Device is not accessable… but after mounting the SD-Card again, i can acceess the files. After unmounting the SD-Card and test it again, i got the same Error. I dont know if the tool got something faulty back…
But at first i got a little more Space on the SD-Card (2,5GB are free now).
I plug it in the Pi again and power it on. The boot process was now successfull and i got the HA-CLI displayed.
Hurraayyy!
I checked if i was able to login to the HA GUI, ping was working but no HTTPs. I tried with Powershell and the Command “test-netconnection 192.168.2.42 -port 8123” and got the feedback that ping was working but the Port was not open:
grafik
Damn…
So i went back the the Pi again and tooked a look at the CLI.
i tried the command “supervisor repair” and some other commands with the Option “repair” but all i got was a Error
“FATA[0000] Error while executing rootCmd: accepts 1 arg(s), received 0”
After this Error i only got the Message for every command
“Error: System is not ready with state: setup”
and here im stuck.
Does someone know how to handle this?
Its seems that the SD-Card is faulty, maybe my backup is faulty too because it has the Name 2ce0d715.tar. And shame on me, i only have the last Backup stored not a few more :-/
It there a way to export my configuration and all the Stuff? I dont want to rebuild all my Enviroment from scratch…
I can access the files at the SD-Card and i have full access to my Pi.
Please write your answer in simple words or with pictures, im not really into the Unix CLI Stuff :-/
Thank you for your help!
Sincerly
Chris
