Hi all!
New here!!
I'm trying to integrate a ceiling light (Mantra Coin) into HA using BLE ADV.
I'm using the mAntra lighting Android app method.
After discovery, ‘mantra_v1 - 0x95BD’ is enabled in HA. I can create the integration, but the light doesn't respond.
I’ve also tried using the “pairing” method with all the options, and none of them have worked.
Could it be that the chip or firmware version is different from what mantra_v1 supports?
Log
"home_assistant": {
"arch": "aarch64",
"dev": false,
"docker": true,
"hassio": true,
"installation_type": "Home Assistant OS",
"os_name": "Linux",
"os_version": "6.12.85-haos",
"python_version": "3.14.5",
"timezone": "Europe/Madrid",
"version": "2026.6.3",
"virtualenv": false,
"container_arch": "aarch64",
"supervisor": "2026.06.1",
"host_os": "Home Assistant OS 17.3",
"docker_version": "29.3.1",
"chassis": "embedded",
"run_as_root": true
"manifest": {
"domain": "ble_adv",
"name": "BLE ADV Ceiling Fan / Lamps",
"after_dependencies": [
"esphome"
"codeowners": [
"NicoIIT"
"config_flow": true,
"documentation": "https://github.com/NicoIIT/ha-ble-adv",
"integration_type": "device",
"iot_class": "assumed_state",
"issue_tracker": "https://github.com/NicoIIT/ha-ble-adv/issues",
"requirements": [
"pycryptodome",
"btsocket"
"version": "v2.0.3",
"is_built_in": false,
"overwrites_built_in": false
"coordinator": {
"hci": {
"adapters": {
"hci/XX:XX:XX:XX:XX:XX": {
"type": "BluetoothHCIAdapter",
"mac": "XX:XX:XX:XX:XX:XX",
"available": true,
"queue": 4,
"dequeueing": true,
"logs": [
"2026-06-14 18:35:41.885695 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0008064853E0EAB4AAC07B24C29646ED",
"2026-06-14 18:35:41.997280 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0008064853E0EAB4AAC07B24C29646ED",
"2026-06-14 18:35:42.105348 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0008064853E0EAB4AAC07B24C29646ED",
"2026-06-14 18:35:42.214379 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0008064853E0EAB4AAC07B24C29646ED",
"2026-06-14 18:35:42.324337 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0008064853E0EAB4AAC07B24C29646ED",
"2026-06-14 18:35:42.434368 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0008064853E0EAB4AAC07B24C29646ED",
"2026-06-14 18:35:49.540657 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0009064852F354040406FE2973EDA719",
"2026-06-14 18:35:49.649529 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0009064852F354040406FE2973EDA719",
"2026-06-14 18:35:49.759513 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0009064852F354040406FE2973EDA719",
"2026-06-14 18:35:49.867458 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0009064852F354040406FE2973EDA719",
"2026-06-14 18:35:49.977471 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0009064852F354040406FE2973EDA719",
"2026-06-14 18:35:50.086468 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F0009064852F354040406FE2973EDA719",
"2026-06-14 18:35:50.595058 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000A064851C797D5F74D773FA0618504",
"2026-06-14 18:35:50.704471 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000A064851C797D5F74D773FA0618504",
"2026-06-14 18:35:50.812474 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000A064851C797D5F74D773FA0618504",
"2026-06-14 18:35:50.923490 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000A064851C797D5F74D773FA0618504",
"2026-06-14 18:35:51.034469 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000A064851C797D5F74D773FA0618504",
"2026-06-14 18:35:51.148528 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000A064851C797D5F74D773FA0618504",
"2026-06-14 18:35:51.658979 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000B064850D42965598BF232111A64F0",
"2026-06-14 18:35:51.767467 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000B064850D42965598BF232111A64F0",
"2026-06-14 18:35:51.879527 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000B064850D42965598BF232111A64F0",
"2026-06-14 18:35:51.987497 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000B064850D42965598BF232111A64F0",
"2026-06-14 18:35:52.096481 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000B064850D42965598BF232111A64F0",
"2026-06-14 18:35:52.204498 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000B064850D42965598BF232111A64F0",
"2026-06-14 18:35:52.717184 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000C064857AE107611DA63120779C13F",
"2026-06-14 18:35:52.826468 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000C064857AE107611DA63120779C13F",
"2026-06-14 18:35:52.938507 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000C064857AE107611DA63120779C13F",
"2026-06-14 18:35:53.047479 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000C064857AE107611DA63120779C13F",
"2026-06-14 18:35:53.156498 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000C064857AE107611DA63120779C13F",
"2026-06-14 18:35:53.266507 - Advertising - duration: 100ms, repeat: 1, 02011A15FF4E6F720F000C064857AE107611DA63120779C13F"
"extended_adv": false,
"mgmt_adv": false
"ids": {
"0": "hci/XX:XX:XX:XX:XX:XX"
"logs": [
"2026-06-14 18:31:41.882889 - MGMT Connected - fileno: 84",
"2026-06-14 18:31:41.884634 - MGMT Nb HCI Adapters: 1",
"2026-06-14 18:31:41.886136 - MGMT - HCI Adapters: [(0, 'XX:XX:XX:XX:XX:XX')]",
"2026-06-14 18:31:41.886408 - Adding adapter 'hci/XX:XX:XX:XX:XX:XX'/'0' of type BluetoothHCIAdapter"
"supported_by_host": true
"esp": {
"adapters": {},
"ids": {},
"logs": [
"2026-06-14 18:31:41.881174 - BLE ADV Name Entities: []"
"ign_adapters": [],
"ign_duration": 60000,
"ign_cids": [
65231,
64903,
65162,
65163,
64908,
64918,
65049,
65183,
65184,
65061,
65062,
65063,
65194,
65068,
64689,
64822,
65223,
65224,
65225,
65226,
65227,
65228,
65229,
65230,
64719,
65104,
65233,
65234,
65235,
65236,
65109,
65110,
64598,
65240,
65232,
64994,
64867,
64866,
64879,
65008,
64753,
65267,
65268,
64627
"ign_macs": [],
"adapter_macs": [
"XX:XX:XX:XX:XX:XX"
"last_unk_raw": {
"1BFF75004204018066A0D7F39EED27A2D7F39EED2601020000000000": "2026-06-14T18:37:02.800381",
"02011A0AFF4C00100507183A6A62020A00": "2026-06-14T18:37:02.139524",
"02011A0CFF4C001007241B5F4B69F758020A00": "2026-06-14T18:37:02.568365",
"02010213FFFFFF35366134643366353765646361323863020AF103035634": "2026-06-14T18:37:02.654437",
"1BFF75004204018066C8A6EF4F0BB7CAA6EF4F0BB60102B400000000": "2026-06-14T18:37:02.832557",
"0201021BFF7500021842B1D460C554961FCA92BA7765C225EB73E6107999A0": "2026-06-14T18:37:02.198661",
"02011A020A110BFF4C001006061D13C32678": "2026-06-14T18:37:02.730554",
"02011A09FFC4000333021315800303B9FE081B0043BC822AE6B4": "2026-06-14T18:37:02.424505",
"02011805030F180218": "2026-06-14T18:37:02.343328",
"0201010319C0000303E7FE0409503937": "2026-06-14T18:37:01.875287",
"0201060E1695FE1059083500C49675FDCE8C0516ABFD0101": "2026-06-14T18:37:01.800316",
"0201060F1695FE30585B05EA83CBCB38C1A408": "2026-06-14T18:37:01.280459",
"02011A15FF4E6F720F497C23F241EA9F2BC7F64F773DC0EEDD": "2026-06-14T18:36:12.680722",
"02011A15FF4E6F720F889FB43E8ED3B2EF1A8C3831515EE6E5": "2026-06-14T18:36:08.720680",
"02011A15FF4E6F720F663CCCDF951FB0E6C33437A9A3AC6973": "2026-06-14T18:36:09.738731",
"02011A15FF4E6F720F603F77D9FFACD0D1A76B901868647054": "2026-06-14T18:36:11.687820",
"02011A15FF4E6F720FDCF2C16F7F369AC0C3EE553176747482": "2026-06-14T18:36:13.701680",
"02010215FF4E6F720F002406487D4433E6BF3E91C9A3DAF00A": "2026-06-14T18:36:18.553797",
"02011A0BFF4C001006251E5A9F3A00020A00": "2026-06-14T18:36:18.267851",
"02010215FF4E6F720F0026064B7F634E87E2B30FA8C42FA089": "2026-06-14T18:36:18.777848",
"02010215FF4E6F720F0027064B7E70F0374C7589BB75544140": "2026-06-14T18:36:18.893861",
"02010215FF4E6F720F0028064B71973CA172102BC9E8E8EB33": "2026-06-14T18:36:19.021865",
"02010215FF4E6F720F0029064B70848211DCD6ADC259930AD9": "2026-06-14T18:36:20.000930",
"02011A15FF4E6F720F51C571EB54E93ECC14AF7B63E34637FA": "2026-06-14T18:36:19.669831",
"02010215FF4E6F720F002A064B73B041C02F9D4B89881D4495": "2026-06-14T18:36:20.623850",
"02010215FF4E6F720F002B064B72A3FF70815BCD043967A521": "2026-06-14T18:36:22.945870",
"02011A15FF4E6F720F002B06BF72A3FF70815BCD043E765B62": "2026-06-14T18:36:20.695824",
"02011A15FF4E6F720FA8BBAB1CDF3C8BE0A987A81EC7F3CEC2": "2026-06-14T18:36:22.689026",
"02010215FF4E6F720F002C064B75D9C663C90A5FA42F0500AE": "2026-06-14T18:36:25.835872",
"02011A15FF4E6F720FFF0DC44ECDB85B1E809A8C59C01EF4AE": "2026-06-14T18:36:28.727966",
"02011A15FF4E6F720F210D3F9C32D50BB0A95BA381B1CD4427": "2026-06-14T18:36:56.714280",
"02011A15FF4E6F720F128479ACCA7AD615E1C168D2789A9479": "2026-06-14T18:36:40.763052",
"02011A15FF4E6F720F2CBE11914BC35A4AE545D8DDAC1A3F58": "2026-06-14T18:36:45.670149",
"02011A15FF4E6F720F889DB43E8CF4CF8E4701CB2A33A9250C": "2026-06-14T18:36:53.706217",
"02011A15FF4E6F720F167F92A87155EB9998FCC0B51484CD52": "2026-06-14T18:37:01.691404"
"last_dec_raw": {}
"entries": {},
"flow": [
"2026-06-14 18:35:13.251113 - Config flow 'user' started.",
"2026-06-14 18:35:20.324614 - Wait Config - Raw advs: ['02010215FF4E6F720F002406487D4433E6BF3E91C9A3DAF00A', '02011A0BFF4C001006251E5A9F3A00020A00', '02010215FF4E6F720F0026064B7F634E87E2B30FA8C42FA089', '02010215FF4E6F720F0027064B7E70F0374C7589BB75544140', '02010215FF4E6F720F0028064B71973CA172102BC9E8E8EB33', '02010215FF4E6F720F0029064B70848211DCD6ADC259930AD9', '02011A15FF4E6F720F51C571EB54E93ECC14AF7B63E34637FA', '02010215FF4E6F720F002A064B73B041C02F9D4B89881D4495']",
"2026-06-14 18:35:20.324701 - Wait Config - Confs: {'hci/XX:XX:XX:XX:XX:XX': [mantra_v1 - 0x95BD - 0]}",
"2026-06-14 18:35:20.368139 - Start blink - hci/XX:XX:XX:XX:XX:XX / mantra_v1 - 0x95BD - 0.",
"2026-06-14 18:35:24.373696 - Stop blink.",
"2026-06-14 18:35:38.700250 - Start blink - hci/XX:XX:XX:XX:XX:XX / mantra_v1 - 0x95BD - 0.",
"2026-06-14 18:35:42.707147 - Stop blink.",
"2026-06-14 18:35:49.537147 - Start blink - hci/XX:XX:XX:XX:XX:XX / mantra_v1 - 0x95BD - 0.",
"2026-06-14 18:35:53.543022 - Stop blink."
