Ha-db-universal-migrator - migrate your recorder database between SQLite, MariaDB, MySQL and PostgreSQL without losing history
ha-db-universal-migrator
GitHub ReleaseBuy Me A CoffeeGitHub Downloads
Migrate the Home Assistant recorder database between engines — SQLite, MariaDB, MySQL, PostgreSQL — in any direction, keeping the full history: states, events, long-term statistics, everything.
Home Assistant’s own position is that changing the recorder database is not supported and loses history. This script exists because that doesn’t have to be true.
The script has its own thread in the Scripts category of the Home Assistant community forum: ha-db-universal-migrator. Questions, feedback and reports of engine pairs you have run are welcome there; bugs are better as issues.
Supported migrations
Any engine to any other engine. Sources are rows, targets are columns.
source ↓ / target → SQLite MariaDB MySQL PostgreSQL
SQLite ◐ :white_check_mark: :check_box_with_check: :white_check_mark:
MariaDB :check_box_with_check: ◐ :check_box_with_check: :white_check_mark: production
MySQL :check_box_with_check: :check_box_with_check: ◐ :check_box_with_check:
PostgreSQL :white_check_mark: :check_box_with_check: :check_box_with_check: ◐
:white_check_mark: tested run end-to-end against a real server, every table compared value by value afterwards: strings with escapes and Unicode, booleans, binary context IDs, floats, timezone-aware timestamps, the self-referencing foreign key on states
:white_check_mark: production the above, plus a real Home Assistant instance migrated and running on the result (see A real run)
:check_box_with_check: supported same code path as a tested combination, not exercised against a server
◐ same engine allowed only between different databases (another server, another file); the script refuses to migrate a database onto itself
MariaDB and MySQL share one code path (SQLAlchemy backend mysql). Engine versions HA supports: MariaDB ≥ 10.3, MySQL ≥ 8.0, PostgreSQL ≥ 12, SQLite ≥ 3.40.1. Pre-flight checks both ends against these minimums — a target below them aborts (HA would refuse to start on it), a source below them warns.
What makes it different
  • No DDL is shipped, no HA version is pinned. The target schema is generated at run time from the recorder models installed in the Home Assistant you are running (Base.metadata.create_all), which is exactly how the recorder creates a fresh database. Whatever schema version your HA is on, that is the schema you get.
  • Refuses to guess. The source’s schema_version (from its schema_changes table) must equal the installed models’ SCHEMA_VERSION, or nothing is written.
  • Source is detected, not configured. It reads recorder.db_url from your configuration.yaml using HA’s own YAML loader — !secret, !include and packages resolve exactly as HA resolves them. No db_url means the recorder’s default SQLite file.
  • Column-level diff before the copy. Columns present on only one side (legacy leftovers from years of migrations) are reported and skipped; a target-only NOT NULL column aborts the run before any data moves.
  • Fast. PostgreSQL targets load via COPY; MariaDB/MySQL/SQLite via batched multi-row inserts. Indexes and foreign keys are dropped for the load and rebuilt afterwards. Batch sizes are auto-sized per table from the measured row width, the process’s memory limit and the target’s max_allowed_packet.
  • Verified. Per-table row counts are compared source vs target at the end; a mismatch exits non-zero and tells you not to switch.
  • Dry-run first. --dry-run executes the entire pre-flight — imports, source detection, connections, row counts, column diff, target checks, schema-version gate — and writes nothing.
Prerequisites
Home Assistant stopped for the whole run The one hard rule. Guarantees the source, its dump and SCHEMA_VERSION agree. The script checks for other sessions on the source and aborts if it finds any.
Run with HA’s own Python The homeassistant package must be importable — that is where the schema comes from. See Usage for each install type.
DB drivers psycopg2 for PostgreSQL, mysqlclient (MySQLdb) or pymysql for MariaDB/MySQL. The official HA container image ships both.
Network reach From where the script runs to both the source and the target server.
Target database Either created by you (UTF8 on PostgreSQL, utf8mb4 on MariaDB/MySQL, owned by the HA account) or created by the script if you give it admin credentials.
A backup of the source The script never modifies the source, but take a dump anyway. It is your rollback.
Free disk on the target At least the logical size of the source database, plus WAL headroom on PostgreSQL.
No superuser is needed for the migration itself. The only privileged operations — creating the database and the account — are either done by you beforehand or by the optional DST_ADMIN_* bootstrap, which is used for those two statements and nothing else.
Configuration
Edit the block at the top of the script. Every value can also be set as an environment variable of the same name.
# Source: detected from HA's configuration
HA_CONFIG_DIR = "/config"        # directory containing configuration.yaml
SRC_DB_URL    = ""               # override only if detection can't parse your config
# Target
DST_TYPE      = "postgresql"     # postgresql | mariadb | mysql | sqlite
DST_HOST      = "10.0.0.10"
DST_PORT      = 0                # 0 = engine default
DST_DB        = "homeassistant"
DST_USER      = "homeassistant"
DST_PASSWORD  = ""
DST_DB_URL    = ""               # or a full SQLAlchemy URL instead of the fields above
DST_SQLITE_PATH = "/config/home-assistant_v2.new.db"   # sqlite target only
# Optional bootstrap: creates DST_USER and DST_DB if missing, then never used again
DST_ADMIN_USER     = ""          # "postgres" / "root"
DST_ADMIN_PASSWORD = ""
# Copy behaviour
BATCH_ROWS   = 0                 # 0 = auto per table
INSERT_ROWS  = 0                 # 0 = auto per table (MariaDB/MySQL/SQLite targets)
LOG_FILE     = "/config/ha-db-universal-migrator.log"
PG_MAINTENANCE_WORK_MEM = ""     # e.g. "1GB" for the index rebuild on a PostgreSQL target
# Safety
REQUIRE_EMPTY_TARGET = True      # abort if the target already has tables
REQUIRE_QUIET_SOURCE = True      # abort if the source has other sessions
ASSUME_YES           = False     # skip the confirmation prompt (same as --yes)
Passwords with special characters go in DST_PASSWORD literally — the script builds the URL and encodes them. If you use DST_DB_URL or SRC_DB_URL instead, percent-encode @ : / ? # % yourself.
Usage
Put the script in HA’s config directory, then run it with HA’s interpreter:
# Container (docker compose)
docker compose run --rm --entrypoint python3 homeassistant /config/ha-db-universal-migrator.py --dry-run
# Core / venv
source /srv/homeassistant/bin/activate
python3 ha-db-universal-migrator.py --dry-run
# Supervised
docker exec -it homeassistant python3 /config/ha-db-universal-migrator.py --dry-run
Flags: --dry-run runs pre-flight only and writes nothing; --yes skips the confirmation prompt.
Recommended sequence:
  1. Stop Home Assistant.
  2. Dump the source database.
  3. --dry-run. Read the report.
  4. Real run. Answer y.
  5. On “no mismatches”: point recorder.db_url at the new database, start Home Assistant, watch the log for recorder warnings on first start.
  6. Keep the source until you are satisfied.
A failed load leaves the target partial: drop the target database (or file) and re-run. There is no resume.
A real run
MariaDB 11.8 → PostgreSQL 18.6, Home Assistant 2026.9.2, schema version 53, on a Proxmox homelab (both databases in LXCs on the same node; the PostgreSQL LXC had 4 vCPU / 4 GB / NVMe-backed ZFS, PG_MAINTENANCE_WORK_MEM = "1GB", max_parallel_maintenance_workers = 3).
Rows 31,835,998 across 13 tables — states 11.5M, statistics 15.3M, statistics_short_term 3.6M
Source size 5.4 GB logical
Copy states 153 s at ~75k rows/s; statistics 162 s at ~95k rows/s
Index + FK rebuild ~70 s for 20 indexes and 7 foreign keys
Script total 6.9 minutes, 13/13 tables matched
HA downtime, stop to start 18 minutes including the dump and post-checks
On first start the recorder logged only Ended unfinished session for the run it had left open on the old database, and carried on. HA’s System Information panel reported Oldest run start time from twelve days earlier — the history had come along.
What it does, step by step
  1. Pre-flight — import homeassistant, print version and SCHEMA_VERSION; detect the source from configuration.yaml; connect to it; read schema_changes; check for other sessions; count rows and diff columns per table against the models; bootstrap or verify the target; assert schema versions are equal; print the plan; ask for confirmation.
  2. Create target schema from the installed models.
  3. Drop foreign keys and indexes on the target (captured via the SQLAlchemy inspector, rebuilt from the model metadata — no engine-specific catalog queries).
  4. Copy every table in foreign-key dependency order (Base.metadata.sorted_tables), keyset-paginated on the integer primary key, with per-table auto-sized batches.
  5. Rebuild indexes and foreign keys; reset sequences / AUTO_INCREMENT to the real high-water marks; ANALYZE.
  6. Verify row counts per table and the target’s schema_version.
Known limitations
  • Sessions visible on a MariaDB/MySQL source require the PROCESS privilege to include other users’ connections. Without it the quiet check sees only the HA account’s own sessions — which is the case that matters when HA was the only client.
  • mysqlclient builds one multi-row statement per batch and does not split it; the auto-sized INSERT_ROWS keeps it under max_allowed_packet. pymysql splits on its own.
  • A freshly created schema is not guaranteed identical to a migrated one at the same version — HA’s migrations have occasionally left columns behind. The column diff handles the common case (source-only leftovers are skipped). A target-only NOT NULL column without a default aborts.
  • TimescaleDB and other extensions are not involved; the recorder uses plain SQL and so does this script.
  • No resume. A failed copy means drop the target and re-run.
AI-assisted development
This script is built by Alessandro (@alexdelprete) & Claude — a human and an LLM working together.
The design is Alessandro’s: detecting the source from Home Assistant’s own configuration instead of asking for it, generating the target schema from the installed Home Assistant models so that no DDL is shipped and no version is pinned, making the tool engine-independent in both directions, the pre-flight-then-confirm structure, the configuration block, per-environment batch sizing, and the operational rules (Home Assistant stopped for the whole run, nothing written before the schema-version gate). Claude’s first proposal was the conventional shape — a pinned schema, a start/stop cycle to let HA create the target, a hard-coded source — and was reworked step by step from those decisions.
The implementation, the test harness against real database servers, the debugging against a live HA package, and most of this documentation were written by Claude.
There is no CI on this repository. Verification is the test matrix in Supported migrations — four engine pairs run end-to-end against live servers with every table compared value by value — and the production migration described in A real run, which was executed against Alessandro’s own Home Assistant with this exact script. This note is here because transparency about how software is made matters more than pretending otherwise.
Coffee
If you find this useful, I’ll gladly accept some quality coffee, but please don’t feel obliged. :slight_smile:
BuyMeCoffee
License
This project is licensed under the MIT License - see the LICENSE file for details.
Acknowledgements
The idea of resetting sequences after the copy and the “let HA create the schema, then load data only” pattern come from years of community write-ups on the Home Assistant forum. This script’s contribution is doing both from the installed models instead of a shipped DDL file, and doing it for every engine pair.
