HA Docker Documentation Page Update
I’m trying to install HA using docker and I found this page listing all available docker images. The HA documentation does not refer to the docker hub page at all.
I am wondering if the doc page should refer people and tell them to install the correct docker image depending on the device they are using.
Or does the docker run command given in the docs automatically pick the correct docker image to use?
$ docker run -d --name="home-assistant" -v /path/to/your/config:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant
A lot of those images are hass.io specific.
If you’re running on a pi, you can’t run the normal home assistant image anyway since it’s built on x86.
