HA does not see when add-ons are launched
Reinstalled HA, solving the problem of an unhealthy system and portainer. (The disk has been fully formatted)
After reinstalling, I ran into the following problem:
some add-ons (at least samba and zigbee2mqtt) start and work fine if you access them via a direct link (ip:port), but HA itself does not fix them in the interface and when you try to access their page, it says that the add-on is not running and throws it to the corresponding add-ons page, where this add-on “allegedly” needs to be launched, but when you click on the start button, nothing happens.
How to make it so that in the same zigbee2mqtt web interface you can safely go from HA itself, without crutches in the form of direct links?
