Ha - Electricity usage - Sonoff POWCT
Hi!
I installed the following Power meter POW Ring Smart Power Meter | POWCT - SONOFF Official and connected it to ha throun LAN Control - Sonoff Integration 3.8.2.
I also set the correct timezone via eWelink.
When I configuered the energy module within ha, after the first day, i get this error in the mesurement. Apparently it considers the total energy of the previous day as negative, and start to count from that value:
any suggestion to solve it?
Hello, the sensor you used in the Energy dashboard is not of the correct type. The sensor must be a “total increasing”, meaning that the kWh number must never “decrease”. If you can find that sensor inside the one out of the box by the integration, you can create an Helper using Integral.
Federico
