New to HA. Wanting to do some monitoring/control and HA looks quite interesting and capable. I don’t know much about it yet, so looking for ideas and input – point me in some viable directions!
What device(s)/system would you suggest for our needs? It sounds like a mini computer may be the way, like N100? But I don’t know what specs are needed. Want something that’s dependable though.
Some potential areas HA could be used, the main things being the solar inverter/battery systems and heating:
1. Solar inverter (Sol-ark 15k and Pytes battery grid-tied; SRNE and JK BMS off-grid)
Better monitoring and control (Sol-ark app isn’t great, but also dependent on internet/Sol-ark).
For example, adjust how the inverter and batteries function (export/import) according to the hourly electricity price.
Some people use Solar Assistant for this, but I’d rather avoid their pay model. I’ve seen people doing other ways, I think it involved ESP Home (not familiar with that).
2. HVAC - 2 stage heat pump (heat/AC), possibly electric resistive heat. Plus separate propane boiler in-floor heat. HRV.
For example, adjust heating based on electricity pricing. Be able to adjust how the thermostat operates (e.g. increase differential so it cycles less, or use other sources if outside temperature is cold).
- I wonder if a “making” a thermostat (temp probe and output contacts) would be the better way (compared to trying to find a compatible thermostat).
3. Energy/power monitoring/control - The inverter has data on the whole house and its own function, but possibly could do some individual circuits like the heat pump, or there’s a separate accessory building that is not part of the house system.
4. Reolink cameras - 5 outdoor cameras with Reolink NVR. Not sure if there’s a practical way to integrate/improve this with HA. We still need to figure the detection out better as we’re getting too many false notifications.
5. Accessory building (garage with small apartment) - possibly monitor temperature/humidity, water leaks, and do things with heating, energy monitoring, etc.
This is on the same LAN as the house, connected with (private) fibre link. So devices here would not be able to connect directly to the HA computer, and need to connect through the LAN. Not sure how that’d work - are there devices that do this, or would we be looking at another Pi/computer for a separate building?
Other thoughts.
Internet firewall/filtering - not sure if this could relate into HA, or maybe the mini computer can help do this (or should be separate device)? And/or I wonder about content filtering, like ads?
Also wonder about local voice control.
Let me know your thoughts!
