HA freezes after reboot
Hello
I have a very well functioning HA instance that was running for around 3 years on a RPi 4. At the beggining, sometimes it crashed and needed a reboot from time to time.
I then created an automation in node red to reboot it every morning and it worked beautifully.
Last week, I migrated the system onto a RPi 5.
Everything is working great, except that it doesn,t boot after the reboot automation activates.
So, everyday at 4am the automation runs but the system doesn’t boot again without me unplugging power and plugging it it back again.
I have tried to manually reboot but performing the action “hassio.host_reboot”, which is the same thing the automation does and it works great.
Any ideas?
Any kind of logs I can provide to help troubleshooting the issue?
Thank you in advance and sorry for my English from Portugal.
See steps 4 & 5 here: How to Troubleshoot Raspberry Pi Crashing.
Note: you should not need to reboot daily if everything is working ok. There is probably a misbehaving automation or integration if you do need to boot daily.
2024.5+: Tracking down instability issues caused by integrations.
Thank you for your help, I will try to studdy that. Ind the meanwhile, the log shows something that doesn’t look right for me at the end…
2025-01-31 04:01:32.043 homeassistant systemd[1]: docker-6b6251599e197b361e96f1ec49e0e0ea1e64a25caeffd9a879f709cf7769dc3a.scope: Consumed 25.861s CPU time.
2025-01-31 04:01:32.044 homeassistant kernel: audit: type=1334 audit(1738296092.037:588): prog-id=36 op=UNLOAD
2025-01-31 04:01:32.059 homeassistant dockerd[642]: time="2025-01-31T04:01:32.059080545Z" level=info msg="ignoring event" container=6b6251599e197b361e96f1ec49e0e0ea1e64a25caeffd9a879f709cf7769dc3a module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
2025-01-31 04:01:32.088 homeassistant kernel: vethae83a0a: renamed from eth0
2025-01-31 04:01:32.120 homeassistant kernel: hassio: port 5(veth1248bf3) entered disabled state
2025-01-31 04:01:32.142 homeassistant NetworkManager[533]: <info>  [1738296092.1425] manager: (vethae83a0a): new Veth device (/org/freedesktop/NetworkManager/Devices/57)
2025-01-31 04:01:32.152 homeassistant kernel: hassio: port 5(veth1248bf3) entered disabled state
2025-01-31 04:01:32.156 homeassistant kernel: veth1248bf3 (unregistering): left allmulticast mode
2025-01-31 04:01:32.156 homeassistant kernel: veth1248bf3 (unregistering): left promiscuous mode
2025-01-31 04:01:32.156 homeassistant kernel: hassio: port 5(veth1248bf3) entered disabled state
2025-01-31 04:01:32.156 homeassistant kernel: audit: type=1700 audit(1738296092.145:589): dev=veth1248bf3 prom=0 old_prom=256 auid=4294967295 uid=0 gid=0 ses=4294967295
2025-01-31 04:01:32.207 homeassistant kernel: audit: type=1300 audit(1738296092.145:589): arch=c00000b7 syscall=206 success=yes exit=32 a0=d a1=4000cc1a40 a2=20 a3=0 items=0 ppid=1 pid=642 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="dockerd" exe="/usr/bin/dockerd" subj=unconfined key=(null)
2025-01-31 04:01:32.207 homeassistant kernel: audit: type=1327 audit(1738296092.145:589): proctitle=2F7573722F62696E2F646F636B657264002D480066643A2F2F002D2D636F6E7461696E6572643D2F72756E2F636F6E7461696E6572642F636F6E7461696E6572642E736F636B
2025-01-31 04:01:32.226 homeassistant systemd[1]: var-lib-docker-overlay2-dbdb2658a8fccc6003bec9252c2f901cfdfef6247f4e903cba3a0db9dd34628a-merged.mount: Deactivated successfully.
2025-01-31 04:01:32.226 homeassistant systemd[1]: mnt-data-docker-overlay2-dbdb2658a8fccc6003bec9252c2f901cfdfef6247f4e903cba3a0db9dd34628a-merged.mount: Deactivated successfully.
2025-01-31 04:01:32.364 homeassistant kernel: audit: type=1334 audit(1738296092.357:590): prog-id=39 op=UNLOAD
2025-01-31 04:01:35.334 homeassistant systemd[1]: docker-eccb4cb3411f0a2018c372374a9bc17e9551d2d9686fe60061de6f0e3c6f2885.scope: Deactivated successfully.
2025-01-31 04:01:35.335 homeassistant systemd[1]: docker-eccb4cb3411f0a2018c372374a9bc17e9551d2d9686fe60061de6f0e3c6f2885.scope: Consumed 11.072s CPU time.
2025-01-31 04:01:35.336 homeassistant kernel: audit: type=1334 audit(1738296095.329:591): prog-id=40 op=UNLOAD
2025-01-31 04:01:35.347 homeassistant dockerd[642]: time="2025-01-31T04:01:35.347846982Z" level=info msg="ignoring event" container=eccb4cb3411f0a2018c372374a9bc17e9551d2d9686fe60061de6f0e3c6f2885 module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
2025-01-31 04:01:35.360 homeassistant kernel: audit: type=1334 audit(1738296095.353:592): prog-id=43 op=UNLOAD
2025-01-31 04:01:35.393 homeassistant systemd[1]: var-lib-docker-overlay2-563db9c5741480b13ff9beafcf3c86b409e9ff78938d001a22c5cfdd87a0b6f6-merged.mount: Deactivated successfully.
2025-01-31 04:01:35.393 homeassistant systemd[1]: mnt-data-docker-overlay2-563db9c5741480b13ff9beafcf3c86b409e9ff78938d001a22c5cfdd87a0b6f6-merged.mount: Deactivated successfully.
2025-01-31 04:01:35.433 homeassistant systemd-logind[543]: The system will reboot now!
2025-01-31 04:01:35.435 homeassistant systemd-logind[543]: System is rebooting.
2025-01-31 04:01:35.447 homeassistant systemd[1]: Removed slice Slice /system/modprobe.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target Bluetooth Support.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target Multi-User System.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target Login Prompts.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target HassOS hardware targets.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target HassOS zram targets.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target Host and Network Name Lookups.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target Remote Encrypted Volumes.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target Remote Verity Protected Volumes.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target RPC Port Mapper.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target Sound Card.
2025-01-31 04:01:35.448 homeassistant systemd[1]: Stopped target Timer Units.
2025-01-31 04:01:35.449 homeassistant systemd[1]: fstrim.timer: Deactivated successfully.
2025-01-31 04:01:35.449 homeassistant systemd[1]: Stopped Discard unused filesystem blocks once a week.
2025-01-31 04:01:35.449 homeassistant systemd[1]: haos-bt-cache.timer: Deactivated successfully.
2025-01-31 04:01:35.449 homeassistant systemd[1]: Stopped Remove Bluetooth cache entries.
2025-01-31 04:01:35.449 homeassistant systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
2025-01-31 04:01:35.449 homeassistant systemd[1]: Stopped Daily Cleanup of Temporary Directories.
2025-01-31 04:01:35.449 homeassistant bluetoothd[567]: Terminating
2025-01-31 04:01:35.450 homeassistant bluetoothd[567]: Destroy Adv Monitor Manager
2025-01-31 04:01:35.450 homeassistant bluetoothd[567]: Battery Provider Manager destroyed
2025-01-31 04:01:35.450 homeassistant bluetoothd[567]: Stopping SDP server
2025-01-31 04:01:35.450 homeassistant bluetoothd[567]: Exit
2025-01-31 04:01:35.450 homeassistant systemd[1]: Stopping Bluetooth service...
2025-01-31 04:01:35.451 homeassistant systemd[1]: Stopping Home Assistant CLI...
2025-01-31 04:01:35.451 homeassistant systemd[1]: hassos-persists.service: Deactivated successfully.
2025-01-31 04:01:35.451 homeassistant systemd[1]: Stopped HassOS persists data on bootstate.
2025-01-31 04:01:35.451 homeassistant systemd[1]: Stopping RPC Bind...
2025-01-31 04:01:35.451 homeassistant systemd[1]: Stopping User Login Management...
2025-01-31 04:01:35.473 homeassistant systemd[1]: Stopping Load/Save OS Random Seed...
2025-01-31 04:01:35.479 homeassistant systemd[1]: rpcbind.service: Deactivated successfully.
2025-01-31 04:01:35.479 homeassistant systemd[1]: Stopped RPC Bind.
2025-01-31 04:01:35.480 homeassistant systemd[1]: bluetooth.service: Deactivated successfully.
2025-01-31 04:01:35.480 homeassistant systemd[1]: Stopped Bluetooth service.
2025-01-31 04:01:35.480 homeassistant systemd[1]: bluetooth.service: Consumed 3min 7.182s CPU time.
2025-01-31 04:01:35.481 homeassistant systemd[1]: [email protected]: Deactivated successfully.
2025-01-31 04:01:35.481 homeassistant systemd[1]: Stopped Home Assistant CLI.
2025-01-31 04:01:35.482 homeassistant systemd[1]: [email protected]: Consumed 1.007s CPU time.
2025-01-31 04:01:35.487 homeassistant systemd[1]: systemd-random-seed.service: Deactivated successfully.
2025-01-31 04:01:35.488 homeassistant systemd[1]: Stopped Load/Save OS Random Seed.
2025-01-31 04:01:35.491 homeassistant systemd[1]: Removed slice Slice /system/ha-cli.
2025-01-31 04:01:35.491 homeassistant systemd[1]: system-ha\x2dcli.slice: Consumed 1.007s CPU time.
2025-01-31 04:01:35.491 homeassistant systemd[1]: [email protected]: Deactivated successfully.
2025-01-31 04:01:35.491 homeassistant systemd[1]: Stopped Raspberry Pi bluetooth helper.
2025-01-31 04:01:35.492 homeassistant systemd[1]: Removed slice Slice /system/bthelper.
2025-01-31 04:01:35.493 homeassistant systemd[1]: Stopping HassOS supervisor...
2025-01-31 04:01:35.494 homeassistant systemd[1]: Stopping Permit User Sessions...
2025-01-31 04:01:35.499 homeassistant systemd[1]: systemd-user-sessions.service: Deactivated successfully.
2025-01-31 04:01:35.499 homeassistant systemd[1]: Stopped Permit User Sessions.
2025-01-31 04:01:35.500 homeassistant systemd[1]: Stopped target Remote File Systems.
2025-01-31 04:01:35.500 homeassistant systemd[1]: Stopped target Preparation for Remote File Systems.
2025-01-31 04:01:35.500 homeassistant systemd[1]: Stopped target NFS client services.
2025-01-31 04:01:35.502 homeassistant systemd[1]: systemd-logind.service: Deactivated successfully.
2025-01-31 04:01:35.502 homeassistant systemd[1]: Stopped User Login Management.
2025-01-31 04:01:35.528 homeassistant kernel: audit: type=1334 audit(1738296095.521:593): prog-id=11 op=UNLOAD
2025-01-31 04:01:35.528 homeassistant kernel: audit: type=1334 audit(1738296095.521:594): prog-id=10 op=UNLOAD
2025-01-31 04:01:35.528 homeassistant kernel: audit: type=1334 audit(1738296095.521:595): prog-id=9 op=UNLOAD
2025-01-31 04:01:38.948 homeassistant systemd[1]: docker-c77251ef3988cc18ab3970891a5454229f6f5fb7e7399b6d7dc0351f3fa68603.scope: Deactivated successfully.
2025-01-31 04:01:38.948 homeassistant systemd[1]: docker-c77251ef3988cc18ab3970891a5454229f6f5fb7e7399b6d7dc0351f3fa68603.scope: Consumed 1min 9.479s CPU time.
2025-01-31 04:01:38.963 homeassistant dockerd[642]: time="2025-01-31T04:01:38.962987401Z" level=info msg="ignoring event" container=c77251ef3988cc18ab3970891a5454229f6f5fb7e7399b6d7dc0351f3fa68603 module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
2025-01-31 04:01:38.996 homeassistant kernel: docker0: port 1(vethfe45011) entered disabled state
2025-01-31 04:01:38.996 homeassistant kernel: vethf53abe4: renamed from eth0
2025-01-31 04:01:39.042 homeassistant NetworkManager[533]: <info>  [1738296099.0429] manager: (vethf53abe4): new Veth device (/org/freedesktop/NetworkManager/Devices/58)
2025-01-31 04:01:39.064 homeassistant kernel: docker0: port 1(vethfe45011) entered disabled state
2025-01-31 04:01:39.068 homeassistant kernel: vethfe45011 (unregistering): left allmulticast mode
2025-01-31 04:01:39.068 homeassistant kernel: vethfe45011 (unregistering): left promiscuous mode
2025-01-31 04:01:39.068 homeassistant kernel: docker0: port 1(vethfe45011) entered disabled state
2025-01-31 04:01:39.068 homeassistant kernel: audit: type=1700 audit(1738296099.060:596): dev=vethfe45011 prom=0 old_prom=256 auid=4294967295 uid=0 gid=0 ses=4294967295
2025-01-31 04:01:39.122 homeassistant kernel: audit: type=1300 audit(1738296099.060:596): arch=c00000b7 syscall=206 success=yes exit=32 a0=d a1=40007003a0 a2=20 a3=0 items=0 ppid=1 pid=642 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="dockerd" exe="/usr/bin/dockerd" subj=unconfined key=(null)
2025-01-31 04:01:39.122 homeassistant kernel: audit: type=1327 audit(1738296099.060:596): proctitle=2F7573722F62696E2F646F636B657264002D480066643A2F2F002D2D636F6E7461696E6572643D2F72756E2F636F6E7461696E6572642F636F6E7461696E6572642E736F636B
2025-01-31 04:01:39.144 homeassistant kernel: hassio: port 2(vethc16b53d) entered disabled state
2025-01-31 04:01:39.144 homeassistant kernel: veth57590f8: renamed from eth1
2025-01-31 04:01:39.194 homeassistant NetworkManager[533]: <info>  [1738296099.1944] manager: (veth57590f8): new Veth device (/org/freedesktop/NetworkManager/Devices/59)
2025-01-31 04:01:39.204 homeassistant kernel: hassio: port 2(vethc16b53d) entered disabled state
2025-01-31 04:01:39.204 homeassistant kernel: vethc16b53d (unregistering): left allmulticast mode
2025-01-31 04:01:39.204 homeassistant kernel: vethc16b53d (unregistering): left promiscuous mode
2025-01-31 04:01:39.204 homeassistant kernel: audit: type=1700 audit(1738296099.200:597): dev=vethc16b53d prom=0 old_prom=256 auid=4294967295 uid=0 gid=0 ses=4294967295
2025-01-31 04:01:39.248 homeassistant kernel: audit: type=1300 audit(1738296099.200:597): arch=c00000b7 syscall=206 success=yes exit=32 a0=d a1=4000700d80 a2=20 a3=0 items=0 ppid=1 pid=642 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="dockerd" exe="/usr/bin/dockerd" subj=unconfined key=(null)
2025-01-31 04:01:39.248 homeassistant kernel: audit: type=1327 audit(1738296099.200:597): proctitle=2F7573722F62696E2F646F636B657264002D480066643A2F2F002D2D636F6E7461696E6572643D2F72756E2F636F6E7461696E6572642F636F6E7461696E6572642E736F636B
2025-01-31 04:01:39.265 homeassistant systemd[1]: var-lib-docker-overlay2-61b306bda578c26b412596046361353b5de8329b9d06d101202301aed0cc049d-merged.mount: Deactivated successfully.
2025-01-31 04:01:39.267 homeassistant systemd[1]: Unmounted /var/lib/docker/overlay2/61b306bda578c26b412596046361353b5de8329b9d06d101202301aed0cc049d/merged.
2025-01-31 04:01:39.267 homeassistant systemd[1]: mnt-data-docker-overlay2-61b306bda578c26b412596046361353b5de8329b9d06d101202301aed0cc049d-merged.mount: Deactivated successfully.
2025-01-31 04:01:39.267 homeassistant systemd[1]: Unmounted /mnt/data/docker/overlay2/61b306bda578c26b412596046361353b5de8329b9d06d101202301aed0cc049d/merged.
2025-01-31 04:01:39.281 homeassistant hassos-supervisor[989]: 0
2025-01-31 04:01:39.283 homeassistant systemd[1]: hassos-supervisor.service: Deactivated successfully.
2025-01-31 04:01:39.284 homeassistant systemd[1]: Stopped HassOS supervisor.
2025-01-31 04:01:39.284 homeassistant systemd[1]: hassos-supervisor.service: Consumed 1.008s CPU time.
2025-01-31 04:01:39.286 homeassistant dockerd[642]: time="2025-01-31T04:01:39.286416879Z" level=info msg="Processing signal 'terminated'"
2025-01-31 04:01:39.286 homeassistant systemd[1]: Stopping Docker Application Container Engine...
2025-01-31 04:01:39.288 homeassistant systemd[1]: Stopping RAUC Update Service...
2025-01-31 04:01:39.289 homeassistant systemd[1]: rauc.service: Deactivated successfully.
2025-01-31 04:01:39.289 homeassistant systemd[1]: Stopped RAUC Update Service.
2025-01-31 04:01:39.295 homeassistant systemd[1]: docker-35c434ec1487f242109658c897be55ba1279ca8b1bf7ee89b4ae3b3828527064.scope: Deactivated successfully.
2025-01-31 04:01:39.296 homeassistant kernel: audit: type=1334 audit(1738296099.292:598): prog-id=16 op=UNLOAD
2025-01-31 04:01:39.307 homeassistant dockerd[642]: time="2025-01-31T04:01:39.306836931Z" level=info msg="ignoring event" container=35c434ec1487f242109658c897be55ba1279ca8b1bf7ee89b4ae3b3828527064 module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
2025-01-31 04:01:39.320 homeassistant dockerd[642]: time="2025-01-31T04:01:39.320099559Z" level=warning msg="ShouldRestart failed, container will not be restarted" container=35c434ec1487f242109658c897be55ba1279ca8b1bf7ee89b4ae3b3828527064 daemonShuttingDown=true error="restart canceled" execDuration=10h35m5.244696252s exitStatus="{2 2025-01-31 04:01:39.297053601 +0000 UTC}" hasBeenManuallyStopped=false restartCount=0
2025-01-31 04:01:39.332 homeassistant kernel: audit: type=1325 audit(1738296099.328:599): table=nat:126 family=2 entries=1 op=nft_unregister_rule pid=178333 subj=unconfined comm="iptables"
2025-01-31 04:01:39.332 homeassistant kernel: audit: type=1300 audit(1738296099.328:599): arch=c00000b7 syscall=211 success=yes exit=512 a0=3 a1=7fdfe8ec98 a2=0 a3=1 items=0 ppid=642 pid=178333 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-nft-multi" subj=unconfined key=(null)
2025-01-31 04:01:39.332 homeassistant kernel: audit: type=1327 audit(1738296099.328:599): proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4400444F434B4552002D7000746370002D6400302F30002D2D64706F72740034333537002D6A00444E4154002D2D746F2D64657374696E6174696F6E003137322E33302E33322E363A38300000002D690068617373696F
2025-01-31 04:01:39.420 homeassistant kernel: hassio: port 1(vethb0f21b8) entered disabled state
2025-01-31 04:01:39.420 homeassistant kernel: veth9809f16: renamed from eth0
2025-01-31 04:01:39.470 homeassistant NetworkManager[533]: <info>  [1738296099.4706] manager: (veth9809f16): new Veth device (/org/freedesktop/NetworkManager/Devices/60)
2025-01-31 04:01:39.480 homeassistant kernel: hassio: port 1(vethb0f21b8) entered disabled state
2025-01-31 04:01:39.480 homeassistant kernel: vethb0f21b8 (unregistering): left allmulticast mode
2025-01-31 04:01:39.480 homeassistant kernel: vethb0f21b8 (unregistering): left promiscuous mode
2025-01-31 04:01:39.532 homeassistant systemd[1]: var-lib-docker-overlay2-32bdd1f39cd7a97dc372d60d45649a39acd6f6dce88dc21a11bd0bf9c1cc22a4-merged.mount: Deactivated successfully.
2025-01-31 04:01:39.533 homeassistant systemd[1]: Unmounted /var/lib/docker/overlay2/32bdd1f39cd7a97dc372d60d45649a39acd6f6dce88dc21a11bd0bf9c1cc22a4/merged.
2025-01-31 04:01:39.533 homeassistant systemd[1]: mnt-data-docker-overlay2-32bdd1f39cd7a97dc372d60d45649a39acd6f6dce88dc21a11bd0bf9c1cc22a4-merged.mount: Deactivated successfully.
2025-01-31 04:01:39.533 homeassistant systemd[1]: Unmounted /mnt/data/docker/overlay2/32bdd1f39cd7a97dc372d60d45649a39acd6f6dce88dc21a11bd0bf9c1cc22a4/merged.
2025-01-31 04:01:39.550 homeassistant dockerd[642]: time="2025-01-31T04:01:39.549997644Z" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd namespace=moby
2025-01-31 04:01:39.550 homeassistant dockerd[642]: time="2025-01-31T04:01:39.550484833Z" level=info msg="Daemon shutdown complete"
2025-01-31 04:01:39.575 homeassistant systemd[1]: docker.service: Deactivated successfully.
2025-01-31 04:01:39.575 homeassistant systemd[1]: Stopped Docker Application Container Engine.
2025-01-31 04:01:39.575 homeassistant systemd[1]: docker.service: Consumed 1min 25.472s CPU time.
2025-01-31 04:01:39.576 homeassistant systemd[1]: Stopping containerd container runtime...
2025-01-31 04:01:39.576 homeassistant systemd[1]: hassos-apparmor.service: Deactivated successfully.
2025-01-31 04:01:39.576 homeassistant systemd[1]: Stopped HassOS AppArmor.
2025-01-31 04:01:39.577 homeassistant systemd[1]: Stopped target System Time Synchronized.
2025-01-31 04:01:39.577 homeassistant systemd[1]: Stopped target System Time Set.
2025-01-31 04:01:39.577 homeassistant systemd[1]: systemd-time-wait-sync.service: Deactivated successfully.
2025-01-31 04:01:39.577 homeassistant systemd[1]: Stopped Wait Until Kernel Time Synchronized.
2025-01-31 04:01:39.578 homeassistant systemd[1]: Stopping Network Time Synchronization...
2025-01-31 04:01:39.581 homeassistant systemd[1]: containerd.service: Deactivated successfully.
2025-01-31 04:01:39.581 homeassistant systemd[1]: Stopped containerd container runtime.
2025-01-31 04:01:39.583 homeassistant systemd[1]: containerd.service: Consumed 4min 10.314s CPU time.
2025-01-31 04:01:39.584 homeassistant systemd[1]: systemd-timesyncd.service: Deactivated successfully.
2025-01-31 04:01:39.584 homeassistant systemd[1]: Stopped Network Time Synchronization.
2025-01-31 04:01:39.584 homeassistant systemd[1]: Stopped target Network is Online.
2025-01-31 04:01:39.585 homeassistant systemd[1]: Stopped target Network.
2025-01-31 04:01:39.585 homeassistant systemd[1]: NetworkManager-wait-online.service: Deactivated successfully.
2025-01-31 04:01:39.585 homeassistant systemd[1]: Stopped Network Manager Wait Online.
2025-01-31 04:01:39.585 homeassistant systemd[1]: Stopping Network Manager...
2025-01-31 04:01:39.585 homeassistant NetworkManager[533]: <info>  [1738296099.5858] caught SIGTERM, shutting down normally.
2025-01-31 04:01:39.586 homeassistant wpa_supplicant[544]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
2025-01-31 04:01:39.586 homeassistant wpa_supplicant[544]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
2025-01-31 04:01:39.586 homeassistant systemd[1]: Stopping WPA supplicant...
2025-01-31 04:01:39.586 homeassistant NetworkManager[533]: <info>  [1738296099.5866] dhcp4 (end0): canceled DHCP transaction
2025-01-31 04:01:39.586 homeassistant NetworkManager[533]: <info>  [1738296099.5866] dhcp4 (end0): activation: beginning transaction (timeout in 45 seconds)
2025-01-31 04:01:39.586 homeassistant NetworkManager[533]: <info>  [1738296099.5867] dhcp4 (end0): state changed no lease
2025-01-31 04:01:39.586 homeassistant NetworkManager[533]: <info>  [1738296099.5869] manager: NetworkManager state is now CONNECTED_SITE
2025-01-31 04:01:39.587 homeassistant NetworkManager[533]: <info>  [1738296099.5871] device (wlan0): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
2025-01-31 04:01:40.113 homeassistant wpa_supplicant[544]: p2p-dev-wlan0: CTRL-EVENT-TERMINATING
2025-01-31 04:01:40.113 homeassistant wpa_supplicant[544]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
2025-01-31 04:01:40.115 homeassistant NetworkManager[533]: <info>  [1738296100.1150] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
2025-01-31 04:01:40.134 homeassistant NetworkManager[533]: <info>  [1738296100.1341] exiting (success)
2025-01-31 04:01:40.157 homeassistant wpa_supplicant[544]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
2025-01-31 04:01:40.157 homeassistant wpa_supplicant[544]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
2025-01-31 04:01:40.165 homeassistant systemd[1]: NetworkManager.service: Deactivated successfully.
2025-01-31 04:01:40.165 homeassistant systemd[1]: Stopped Network Manager.
2025-01-31 04:01:40.165 homeassistant systemd[1]: NetworkManager.service: Consumed 7.536s CPU time.
2025-01-31 04:01:40.166 homeassistant systemd[1]: Stopped target Preparation for Network.
2025-01-31 04:01:40.167 homeassistant systemd[1]: systemd-network-generator.service: Deactivated successfully.
2025-01-31 04:01:40.167 homeassistant systemd[1]: Stopped Generate network units from Kernel command line.
2025-01-31 04:01:40.184 homeassistant wpa_supplicant[544]: wlan0: CTRL-EVENT-TERMINATING
2025-01-31 04:01:40.186 homeassistant systemd[1]: wpa_supplicant.service: Deactivated successfully.
2025-01-31 04:01:40.186 homeassistant systemd[1]: Stopped WPA supplicant.
2025-01-31 04:01:40.187 homeassistant systemd[1]: wpa_supplicant.service: Consumed 2.360s CPU time.
2025-01-31 04:01:40.187 homeassistant systemd[1]: Stopped target Basic System.
2025-01-31 04:01:40.188 homeassistant systemd[1]: Stopped target Path Units.
2025-01-31 04:01:40.188 homeassistant systemd[1]: Stopped target Slice Units.
2025-01-31 04:01:40.188 homeassistant systemd[1]: Removed slice User and Session Slice.
2025-01-31 04:01:40.188 homeassistant systemd[1]: Stopped target Socket Units.
2025-01-31 04:01:40.189 homeassistant systemd[1]: docker.socket: Deactivated successfully.
2025-01-31 04:01:40.189 homeassistant systemd[1]: Closed Docker Socket for the API.
2025-01-31 04:01:40.189 homeassistant systemd[1]: systemd-journal-gatewayd.socket: Deactivated successfully.
2025-01-31 04:01:40.189 homeassistant systemd[1]: Closed Journal Gateway Service Socket.
2025-01-31 04:01:40.189 homeassistant systemd[1]: Stopped target System Initialization.
2025-01-31 04:01:40.190 homeassistant systemd[1]: Stopped target Local Encrypted Volumes.
2025-01-31 04:01:40.190 homeassistant systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
2025-01-31 04:01:40.212 homeassistant systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
2025-01-31 04:01:40.212 homeassistant systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
2025-01-31 04:01:40.220 homeassistant systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
2025-01-31 04:01:40.220 homeassistant systemd[1]: Stopped target HassOS overlay targets.
2025-01-31 04:01:40.221 homeassistant systemd[1]: Stopped target Local Integrity Protected Volumes.
2025-01-31 04:01:40.221 homeassistant systemd[1]: Stopped target Local Verity Protected Volumes.
2025-01-31 04:01:40.221 homeassistant dbus-broker[153]: Dispatched 1644460 messages @ 5(±4)μs / message.
2025-01-31 04:01:40.223 homeassistant systemd[1]: Stopping D-Bus System Message Bus...
2025-01-31 04:01:40.223 homeassistant systemd[1]: Stopping Network Name Resolution...
2025-01-31 04:01:40.227 homeassistant systemd[1]: dbus-broker.service: Deactivated successfully.
2025-01-31 04:01:40.227 homeassistant systemd[1]: Stopped D-Bus System Message Bus.
2025-01-31 04:01:40.227 homeassistant systemd[1]: dbus-broker.service: Consumed 1min 11.728s CPU time.
2025-01-31 04:01:40.227 homeassistant systemd[1]: systemd-resolved.service: Deactivated successfully.
2025-01-31 04:01:40.228 homeassistant systemd[1]: Stopped Network Name Resolution.
2025-01-31 04:01:40.228 homeassistant systemd[1]: systemd-resolved.service: Consumed 13.380s CPU time.
2025-01-31 04:01:40.229 homeassistant systemd[1]: systemd-sysctl.service: Deactivated successfully.
2025-01-31 04:01:40.230 homeassistant systemd[1]: Stopped Apply Kernel Variables.
2025-01-31 04:01:40.230 homeassistant systemd[1]: systemd-coredump.socket: Deactivated successfully.
2025-01-31 04:01:40.230 homeassistant systemd[1]: Closed Process Core Dump Socket.
2025-01-31 04:01:40.230 homeassistant systemd[1]: systemd-modules-load.service: Deactivated successfully.
2025-01-31 04:01:40.230 homeassistant systemd[1]: Stopped Load Kernel Modules.
2025-01-31 04:01:40.230 homeassistant systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
2025-01-31 04:01:40.230 homeassistant systemd[1]: Stopped Create Volatile Files and Directories.
2025-01-31 04:01:40.230 homeassistant systemd[1]: Stopped target Local File Systems.
2025-01-31 04:01:40.261 homeassistant systemd[1]: Unmounting NetworkManager persistent system connections...
2025-01-31 04:01:40.262 homeassistant systemd[1]: Unmounting Dropbear persistent keys...
2025-01-31 04:01:40.264 homeassistant systemd[1]: Unmounting Hostname persistent configuration...
2025-01-31 04:01:40.265 homeassistant systemd[1]: Unmounting Hosts persistent configuration...
2025-01-31 04:01:40.267 homeassistant systemd[1]: Unmounting /etc/machine-id...
2025-01-31 04:01:40.268 homeassistant systemd[1]: Unmounting Kernel persistent modprobe.d...
2025-01-31 04:01:40.269 homeassistant systemd[1]: Unmounting Kernel persistent modules-load.d...
2025-01-31 04:01:40.270 homeassistant systemd[1]: Unmounting Timesyncd persistent configuration...
2025-01-31 04:01:40.271 homeassistant systemd[1]: Unmounting Udev persistent rules.d...
2025-01-31 04:01:40.274 homeassistant systemd[1]: Unmounting USB modeswitch persistent directory...
2025-01-31 04:01:40.274 homeassistant systemd[1]: Unmounting HassOS boot partition...
2025-01-31 04:01:40.275 homeassistant systemd[1]: Unmounting Docker persistent user...
2025-01-31 04:01:40.276 homeassistant systemd[1]: Unmounting Dropbear persistent user...
2025-01-31 04:01:40.278 homeassistant systemd[1]: Unmounting Temporary Directory /tmp...
2025-01-31 04:01:40.280 homeassistant systemd[1]: Unmounting NetworkManager persistent data...
2025-01-31 04:01:40.282 homeassistant systemd[1]: Unmounting Bluetooth persistent state...
2025-01-31 04:01:40.282 homeassistant systemd[1]: Unmounting Docker persistent data...
2025-01-31 04:01:40.282 homeassistant systemd[1]: Unmounting Systemd persistent state...
2025-01-31 04:01:40.283 homeassistant systemd[1]: [email protected]: Deactivated successfully.
2025-01-31 04:01:40.283 homeassistant systemd[1]: Stopped Grow File System on /mnt/data.
2025-01-31 04:01:40.285 homeassistant systemd[1]: Removed slice Slice /system/systemd-growfs.
2025-01-31 04:01:40.286 homeassistant systemd[1]: Stopping Flush Journal to Persistent Storage...
2025-01-31 04:01:40.288 homeassistant kernel: EXT4-fs (zram2): unmounting filesystem ac697ad5-f27f-498e-a901-51647c90c430.
2025-01-31 04:01:40.289 homeassistant systemd[1]: udisks2.service: Deactivated successfully.
