HA Green and Google Nest WiFi Issues
Hi all,
I am a first time user of HA, I received my HA Green today and couldn’t wait to get started.
I have Google mesh Wi-Fi throughout my property, the main Google router is connected to my incoming fibre network via ethernet, an ethernet switch is then connected to the Google router which feeds all my wired devices, Wi-Fi devices are obviously connected wirelessly.
I’ve connected the HA Green to my switch but I am unable to connect to it using a browser on my laptop, which is connected to the Google Wi-Fi. If I connect the laptop to the incoming fibre network Wi-Fi the HA Green appears.
Is this going to pose a problem when it comes to connecting to devices on my Google network, I seem to be struggling.
TIA.
Others are more technical than I am, but the HA has its url on your wifi network, ending in .8123 . It should be something like xxx.xx.xx.8123.
If you have a Nabu account, then it has also another url that you can reach from outside your network.
Try to enter your list of connected devices to your Google Wifi network and look for one ending in .8123
You won’t see any connected devices in the dhcp table showing .8123, that’s the port.
@Flunter what IP address is it reporting if you connect a screen / tv to it and check?
Hi, thanks for the reply.
The problem I have is that the HA Green is connected to my incoming fibre network (even though it is plugged in to the Google router), while everything else is connected to the Google mesh Wi-Fi. Apart from my Phillips Hue bridge, the Green hasn’t found any other devices, such as my Google hubs, Tapo smart plugs etc.
Then that’s the issue, if I understand you correctly you have two dhcps and two networks. Everything needs to be on one network
I will let more technical people respond better, but I have a Google Wifi network. I connected a multiport ethernet box to one of the Google Wifi pods and I connected my Yellow Box to the multiport box.
I don’t suppose there is a work-around, the Wi-Fi from my fibre router won’t reach to my furthest most devices, which is why I have the Google mesh?
Why do you not connect the HA to the Google Wifi ?
Yes, the workaround would be to connect everything to the google wifi. The order is ISP (your fiber) → Google router → Switch → HA Green. Nothing but the Google router should be connected to the ISP box. You should also disable the ISP wifi.
That is exactly how I have it setup at the mo, but my laptop will only connect to the Green when it is on the fiber network, it doesn’t see it when connected to the Google WiFi.
Check and compare the ip addresses of the Green and the device you try to connect to it with.
Just out of curiosity.
There are 2 ethernet ports on the Google router, is there an In and an Out, is it possible I have them connected incorrectly?
The “inbound” I assume is your WAN port (ISP / fiber box) and the “out” is the rest of your network like the switch.
Turns out this WASN’T how I had it setup, my wires were all over the place :innocent:
All sorted now, thank you everyone who contributed :+1:
