HA green can’t install, can’t reach HA website etc…
New to HA, not sure after the trouble it’s gonna be for me but at least wanted get is working.
Tried setting up over wifi first (have an eero three node mesh) did not install could not find server. I tried http://homeassistant.local:8123 I tried http:// “ip address”:8123
I was able to connect to the internet because the home assistant IP shows up on my router app as a connected device. Still couldn’t connect for set up just won’t find a server no matter what url I use.
After that failed I tried Ethernet, did not work either. Can’t even get to the website without an error website not found error. Tried pinging the HA green IP address and ping was good. Just can’t get to the set up page or website for that matter.
After all that, I though issue maybe it was an internet issue and home Assistant wasn’t compatible with my isp so I disconnected my home internet (motem and router) and tried connecting through different ISP (star link). Same exact thing happened. Can’t reach HA website through Ethernet directly plugged into starlink router and could not connect via wifi with my iPhone either.
Before throwing in the towel I tried one last ditch effort, I purchased a different router run of the mill Linuxs router, no luck with new router either. I have tried plugging HA green directly into my motem didn’t work, directly into my gateway eero router no success, tried plugging Ethernet into my upstairs eero. In every instance HA green connects to internet fine, but can’t find server.
Finally, as some suggest I have tried plugging it into a monitor and after home assistant green restart error message csl not running jump into emergency mode. I tried typing login as I saw someone in a different thread post but still went to cli not running-emergency mode.
You know I don’t profess to be an I.T. Aficionado but home assistant Green does advertise out of the box ready-easy installation. Not my experience at all.
Any suggestions?
CSL or CLI?
With the Green connected via Ethernet Do this: Resetting the device – Home Assistant Green
