HA green not working
  • worked fine since installation (>1y ago)
  • no recent changes, last update 1-2 days ago might be root cause
  • green led blinking quick, yellow led blinking slower
  • softreset and hardreset without effect
  • router shows connected
  • observer all green
  • browser says not reachable
  • monitor and keyboard connected, no response after soft/hard reset
  • would like to avoid factory reset via usb
  • any ideas or hints ?
You might need to rebuild it.
Use this for the commands Common tasks - Operating System - Home Assistant
Way down towards the bottom find " Home Assistant via the command line"
Those are the commands you can use via SSH, including booting into safemode
update after last night:
  • HA now accessible again - at least I got the menu.
  • all integrations offline
  • another softreset
  • HA OS update
  • integrations are back
  • no sensor readings
  • another softreset - some readings
  • after and after sensors came back
  • last was ZHA where I needed to trigger each device
  • seems to work now again.
  • but the event left a bad feeling. not sure if this was a hardware problem or an HA OS problem. Can I still rely on it.
Thank you very much for your help.
This time it somehow repaired itself over night and only a few actions from my side where needed. I hope that this will not happen again since all backups were useless under these conditions.
