HA-grow-temperature
HA-grow-temperature
Or visit GitHub
This is a grow room temperature control blueprint for HA.
What is unique about this script is that this script monitors the light switch and sets the temperature of the grow room accordingly.
Higher temp during the day and lower temp during the night.
Setpoint/hysteresis is the difference between min-max temps.
This script also has sanity checking so that if you set the minimum temp above the max temp it will shut down the heater.
Compatability
This blueprint has only been tyested with 26+
If you are using an older version it is recomended that you upgrade before attempting to install this blueprint.
helpers
  • input_number.grow_absolute_max_temp
  • input_number.grow_absolute_minimum_temp
  • input_number.grow_day_temperature_high
  • input_number.grow_day_temperature_low
  • input_number.grow_night_temperature_high
  • input_number.grow_night_temperature_low
switch/sensor entities
  • your-light-switch
  • your-heater-switch
  • your-temperature-sensor
I hope that someone finds this blueprint helpful.
Regards
Fred
