HA hangs randomly - how to find the cause?
I hope I found the right category …
I have HA running on a RasbberryPi 5 with this case, an NVMe drive (HAOS installed to the disk, not an SD) and this Zigbee module.
Everything’s running fine, but now and then the HA isn’t reachable - no WebUI, no access via Android app, no ping reply from the Raspberry.
Sometimes it recovers spontaneously, sometimes I have to start it again.
Where should I look to find the cause for this? I’d really have it running smoothly 24/7 …
Check the logs for errors and warnings.
Add the system monitor integration and keep track of your memory usage.
You may wish to read the existing topic that applies to your situation at:
Sadly it is a hardware design limitation, and frantic use of rosary beads may not help.
