HA has been functioning normally in Amazon echo, but HA is not registered in echo plus after switching to Amazon echo Plus.
In addition, Logitech Harmony or Philips Hugh works without any hub and works normally.
I reconnected the Amazon echo (old) I used to use the HA connection.
Is not HA still ready to connect to the new Amazon ECHO Plus?
For the time being, should I use the old Amazon echo and should I give up HA to use the new model?
Are you using emulated_hue? If so, it has been mentioned several times that the new Plus, Show etc don’t work with it as emulated_hue is using the v1 api and they must have at least v2 api. However, if you leave an older Echo on your network you can still discover devices with that and the new Echos can control them.
