HA in student dorm (client isolation), solving with Tailscale/Cloud?
Hi everyone,
my first post on here, so please correct me if necessary.
I am trying to set up a Home Assistant green in my dorm room, but stumbled into issues with the provided network. After speaking with the Nabu Casa Support and the people managing the network, it seems like the only way of getting the green to work is via a cloud/vpn?
I have loads of questions:
  1. The Home Assistant Cloud and Tailscale seem to been the best options?
  2. Is this possible and practical?
  3. How to set up with no option to reach the green via the network?
  4. What other limitations are there, that i am not yet aware of? (planning to use a ZBT-2 and Thread)
It was suggested to set up my own network, but I am not allowed to do so.
What exactly were the technical network issues?
Without knowing that it is not possible to offer relevant advice.
If they setup like most campus networks your port can see exactly itself and the internet. No exceptions. So you have to plan your network that way.
What we’re you HOPING to do?
I am hoping to set up a way to reach the green.
As suspected, due to the client isolation every device can see it self and the internet. Running fully local isn’t an option.
But if both can see the Internet, there could be a “place” (thought of the Nabu Casa Cloud) where they communicate, allowing me to reach the green.
In my understanding, the same prinziple as a Remote Access, but in this case, it would the standard, even when home.
The network requires all devices to be registered via the MAC-address. I did so (found it by hooking the green up to a display, using the command line), but couldn’t reach the green via App or http://homeassistant.local:8123. This seems to be due to the client isolation, the devices don’t see each other.
If you’re using a Green, there is ET wiring involved((?) The ‘old school’ remedy is to get your own router… a router that lets you manually override its MAC address. Configure the router with the MAC address that campus IT is currently allowing for you into the router. Plug in the green and or wifi connect other “things” to that.
I used to manage IT for call centers and this was discovered… a lot. And sometimes removed when discovered for plugging the router LAN/WAN cables in backwards…
Correct. You would have to setup your own network behind your own router then connect THAT to the port and internet…
Something like tailscale works technically but then EVERYTHING you connected (like all of it) would need to support it’s own independent tailscale client as well as handle firewall traversal (get through your university outbound and then connect to your… (I hope you see how that’s not happening…))
So you’re doing your own network. Sorry.
Yes, the green is wired (ethernet).
Unfortunately i am not allowed to set up a own router network, this would be the “easy” solution.
Something like Tailscale would work for the green? How would the setup be? Would home assistant cloud work too? Are there other options?
I plan on using the ZBT-2, so the “things” would work without wifi. This will limit to Zigbee/thread devices, but that’s better than no home assistant.
Sorry, Wrong… THe HA box supports something like tailscale (read theres plenty of optiosn for allowing it on a vpn)
This is friendly advice… I understand the ask, and the HA box isnt your issue. It’s EVERYTHING else. Dont go down that path. It leads to lots of pain. As a former network engineer, a campus IT engineer, a vendor who supports campus OIT, and speaks TCP - you don’t want to do this, lest you become your campus IT’s enemy #1. OK, #3 behind the dude who is running the pirate radio he thinks nobody knows about and the dude spewing viruses off hislaptop like a plague site. :wink:
Put all your stuff behind your own NAT router then connect THAT to campus outbound and do whatever you want behind your router. (Yes, I just read the no router - which that’s a problem, also you MAC spoof and encrypt the tunnel, they can’t tell, but I digress. No, I will not tell you how.) Start banging the hell out of campus networks for OT devices, you WILL get a visit. (45 individual ot tunnels v 1 tunnel that barely speaks outbound except for bursty am traffic… ) :slight_smile: If they dont just shut your port off first. (My network rules would have, then asked questions later)
Would a Z-Wave based approach work in this environment? Build out your own Z-Wave network that doesn’t touch/depend on the campus one. Plus it would be (relatively) portable when moving to the next dorm room or apartment…
Yep. One ha box all ZWave. Campus only sees HA.
Thanks for the info. Seems like no option to use home assistant without breaking the “no router”-rule?
You can pick something completely local and Internet free like zwave or insteon. Nothing , including HA will get updates, that would have to be done manually somehow
Or, add a router that can let your current MAC address be used, or firewalla, pfsense etc
Perhaps try a cloudflare tunnel? A Cloudflare Tunnel works by having your Home Assistant server initiate an outbound connection to Cloudflare’s servers. Since the server is talking to the internet, not another local device, client isolation might not stop the tunnel from forming.
Hi @lu_1 :wave:
You’re actually in a pretty dang “client isolation dorm network” situation — and you’ve already done the right thing by checking with both Nabu Casa support and the network admins.
Given that they’ve essentially confirmed no local LAN access is possible, your assumption is correct: you need either cloud relay or a VPN-style overlay network.
Best practical solution: Tailscale
In your case, I would strongly recommend focusing on Tailscale rather than cloud access.
Why:
  • Works even in heavily restricted dorm networks
  • No need for router changes or admin rights
  • Bypasses client isolation completely
  • Feels like local access once connected
  • Free for personal use
Home Assistant Green only needs outbound internet → Tailscale builds the secure tunnel over it.
How it works in your setup
Once installed:
  • Home Assistant connects outward to Tailscale
  • Your phone/laptop joins the same Tailscale network
  • You access Home Assistant via a private IP like:
http://100.x.x.x:8123
From Home Assistant’s perspective, your devices are “local”.
Important clarification about Nabu Casa
Since you already spoke with support:
  • If Home Assistant Cloud was already suggested but doesn’t work in your network, that usually means:
    • outbound cloud access may be restricted
    • or the dorm firewall is interfering with relay traffic
In that case, Tailscale is actually the more reliable option, because it uses direct encrypted peer-to-peer connections when possible.
Things to expect in a dorm setup
  • mDNS / discovery will likely be broken (normal)
  • Chromecast / AirPlay / auto-discovery may not work
  • Zigbee + Thread (your ZBT-2) will still work fully locally
  • Automations are unaffected
Optional fallback (if needed later)
If Tailscale ever had issues, the only alternative would be:
  • cloud relay access (if allowed by network policies)
But in restricted dorm networks, VPN overlay solutions are almost always more stable than cloud-only access.
I think this will work
  • Your hardware setup is solid (Green + ZBT-2 + Thread)
  • Network is the only real limitation
  • Tailscale is the most reliable workaround in your exact situation
  • Local LAN fixes won’t apply due to isolation rules
We already discussed why this is not the answer above - THey are NOT trying to get remote access to eh HA box they waned a network to conenct iot devices to. Campus networks are isolated on purpose so the default lan is nogo. NORMAL solution is - install nat rounter gateway.
Op wanted to give access to IOT devices - for this (TailScale or ANY VPN solution) to work they would ALL need to be TS clients and tunnel individually WHICH would get the port shutdown post haste. Without a router the op is limited to pretty much non wifi standardds - meaning Zigbee, Matter, Zwave.
Because Dorm - 2.4G space will be crowded. Zwave is therefore the bezst bet if at all. Cloudflare tunnel Tailscale - it dont matter who’s tunnel - you cant punch that many tunnels out and back in the campus net. Not happening.
I think we’re actually talking about two different network models.
You’re right that campus networks are isolated and that you generally need a NAT/router layer to build your own subnet for IoT devices I’m not disputing that. A small travel router / NAT gateway is usually the clean solution for creating that isolated IoT LAN.
Where I disagree is the assumption that Tailscale (or similar VPNs) would require every IoT device to be a client and individually tunnel out. That’s not how it has to be used.
You can run Tailscale (or any VPN) on a single gateway device acting as a subnet router, and then expose a whole local IoT network behind it. The IoT devices themselves don’t need any VPN client at all. They just sit behind NAT on that local segment.
That said, I do agree with your core point: in a dorm/campus environment, relying on per-device VPN tunneling or anything that looks like multiple outbound tunnels is likely to get flagged or blocked quickly. So in practice, a proper NAT router/gateway creating a local IoT subnet is the correct base design.
And I also agree that for constrained RF environments (crowded 2.4GHz), Zigbee or Z-Wave is often the more reliable direction than Wi-Fi IoT.
So basically NAT gateway is required either way VPN is optional and only useful if you want remote access to that isolated subnet, not as the primary networking solution for each device.
Correct and that was not the Op ask. They wanted to use it as the net substrate why I said no you’ll drive campus IT bananas.
Even easier than Tailscale- look at Zerotier.
Yeah, fair if the idea is to use Tailscale (or any VPN) as the actual network substrate for all IoT traffic, then I agree with you, that’s not realistic on a campus network and would definitely get flagged.
My point was more that it can still be useful on top of a proper setup (like a NAT router) for management/access not as a replacement for the local network itself.
So we’re basically aligned:
  • NAT/router = required for IoT network in a dorm
  • VPN/Tailscale = optional, only for access/management
  • Not viable as the primary transport layer for all devices
