Home Assistant custom integration for legacy Ubiquiti airOS XS2 devices (NanoStation2, PowerStation2, etc).
Features
- SSH polling of
mca-status - Signal, Noise, CCQ, SNR
- TX/RX rate monitoring
- Reboot switch
- Config Flow (UI install)
- HACS compatible
NOTE: I created this because the newer Ubiquiti integration doesn’t work with the OLD antennas. I have a PowerStation and a couple Nano’s that are old Wireless B. I still use them for extended wireless on a large property for Blink cams and smart devices. I wanted to be able to pull data into home assistant and this works.
Hope you find it useful ![]()
