Hi everyone, I’m new and I apologize for any beginner errors. I ask if anyone has already integrated the Huawei photovoltaic system into HA. In essence, the management system is called FusionSolar. I would like to view kW produced, battery kW and % charge, kW consumed and kW entered or imported from the network. I read here and there that someone succeeded but had to change the configuration within fusion (which I would like to avoid). Someone instead managed to intercept the values present within the html page, perhaps with Note red. Thanks everyone for the replies
This is a forum in English. I suggest that you use Google Translate to post your questions in English. - Questo è un forum in inglese. Ti suggerisco di utilizzare Google Translate per pubblicare le tue domande in inglese.
Bringing back the topic as I’m using the same Fusion Solar integration but can’t figure out what are the correct sensors.
I’m struggling with the energy dashboard as I’m not able to spot:
- current PV production
- daily PV yield
- daily energy imported from the grid
- daily energy exported
I’m also having a 5kw battery, thanks for helping!
Hey, you can check the integration I created recently that uses the APIs the front-end uses, as I don’t have access to the OpenAPI. It’s here: GitHub - hcraveiro/Home-Assistant-FusionSolar-App: Integrate FusionSolar App into your Home Assistant.
Is it still working ?
Tried your integration, added the username and password, changed the data host to uni002 instead of uni001 and added the station with the “N=” but I got the “invalid authentification” (tried the password on the fusion solar website and it works).
No logs available. Could you please help ? It’s pretty straight forward so I don’t know what happened
