HA Keeps Rebooting as a few days ago
As of a few days ago my HA keeps rebooting every few minues. I have made any changes, other than a few UI tweaks.
I’ve looked in the logs, but nothing stood out to me as the reason.
Any insights are greatly apprecited.
Running HA 2025.12.3 in a Docker Container.
Here are the logs:
2025-12-16 20:14:39.413 ERROR (MainThread) [habluetooth.manager] Missing required permissions for Bluetooth management: Missing NET_ADMIN/NET_RAW capabilities for Bluetooth management. Automatic adapter recovery is unavailable. Add NET_ADMIN and NET_RAW capabilities to the container to enable it
WARNING: All log messages before absl::InitializeLog() is called are written to STDERR
E0000 00:00:1765944885.207239      67 alts_credentials.cc:93] ALTS creds ignored. Not running on GCP and untrusted ALTS is not enabled.
2025-12-16 20:14:47.816 WARNING (MainThread) [homeassistant.components.withings] Webhook not registered - https and port 443 is required to register the webhook
2025-12-16 20:14:48.034 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Sony Speaker(http://192.168.86.214:54480/sony)] Unable to connect
2025-12-16 20:14:48.036 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Sony Speaker(http://192.168.86.205:54480/sony)] Unable to connect
2025-12-16 20:14:48.037 WARNING (MainThread) [homeassistant.components.media_player] Platform songpal not ready yet: Unable to do POST request: Cannot connect to host 192.168.86.214:54480 ssl:default [Connect call failed ('192.168.86.214', 54480)]: None; Retrying in background in 30 seconds
2025-12-16 20:14:48.038 WARNING (MainThread) [homeassistant.components.media_player] Platform songpal not ready yet: Unable to do POST request: Cannot connect to host 192.168.86.205:54480 ssl:default [Connect call failed ('192.168.86.205', 54480)]: None; Retrying in background in 30 seconds
[20:14:55] INFO: Home Assistant Core finish process exit code 256
[20:14:55] INFO: Home Assistant Core finish process received signal 11
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
2025-12-16 20:15:02.777 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pirateweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:15:02.778 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:15:02.779 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tesla_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:15:02.779 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration playstation_network which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:15:02.780 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:15:02.780 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pirateweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:15:02.781 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:15:02.781 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tesla_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:15:02.781 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration playstation_network which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:15:02.781 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:15:03.726 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-12-16 20:15:03.763 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=208 from 2025-12-17 04:14:38.777643)
2025-12-16 20:15:04.522 ERROR (MainThread) [habluetooth.manager] Missing required permissions for Bluetooth management: Missing NET_ADMIN/NET_RAW capabilities for Bluetooth management. Automatic adapter recovery is unavailable. Add NET_ADMIN and NET_RAW capabilities to the container to enable it
E0000 00:00:1765944911.806845      67 alts_credentials.cc:93] ALTS creds ignored. Not running on GCP and untrusted ALTS is not enabled.
2025-12-16 20:15:14.315 WARNING (MainThread) [homeassistant.components.withings] Webhook not registered - https and port 443 is required to register the webhook
2025-12-16 20:15:14.465 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Sony Speaker(http://192.168.86.214:54480/sony)] Unable to connect
2025-12-16 20:15:14.465 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Sony Speaker(http://192.168.86.205:54480/sony)] Unable to connect
2025-12-16 20:15:14.466 WARNING (MainThread) [homeassistant.components.media_player] Platform songpal not ready yet: Unable to do POST request: Cannot connect to host 192.168.86.214:54480 ssl:default [Connect call failed ('192.168.86.214', 54480)]: None; Retrying in background in 30 seconds
2025-12-16 20:15:14.467 WARNING (MainThread) [homeassistant.components.media_player] Platform songpal not ready yet: Unable to do POST request: Cannot connect to host 192.168.86.205:54480 ssl:default [Connect call failed ('192.168.86.205', 54480)]: None; Retrying in background in 30 seconds
2025-12-16 20:15:37.848 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.sonarr_shows exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2025-12-16 20:15:38.301 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.sonarr_shows exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2025-12-16 20:15:40.001 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Sony Speaker(http://192.168.86.205:54480/sony)] Unable to connect
2025-12-16 20:15:40.002 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Sony Speaker(http://192.168.86.214:54480/sony)] Unable to connect
2025-12-16 20:15:47.417 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.kitchen] Error from stream worker: Not Found error opening stream (Server returned 404 Not Found, rtsps://stream-us1-alfa.dropcam.com:443/sdm_live_stream/CiUA2vuxr0bRVYgkQ9LbDFDK6DjwrlQl1oW9IOQ32OtzpPRbzlu1EnEA7cpCCRBnLfxT_B5ZnJLlioG7HPkvfj_B2GTSL-8ttbBz2ucV6zEVYSqsS97HmabCprAX7xxWCfCm0CDfnK9i-nW1gqDabFVYiPNOWGA_jncFuvAJrJZgDXNUwmSwdq1nGY4whSmWHOLKcGeF6lIDgg?auth=****)
2025-12-16 20:15:55.009 WARNING (SyncWorker_8) [homeassistant.components.ps4.media_player] PS4 could not be reached
2025-12-16 20:16:07.866 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.kitchen] Error from stream worker: Not Found error opening stream (Server returned 404 Not Found, rtsps://stream-us1-alfa.dropcam.com:443/sdm_live_stream/CiUA2vuxr0bRVYgkQ9LbDFDK6DjwrlQl1oW9IOQ32OtzpPRbzlu1EnEA7cpCCRBnLfxT_B5ZnJLlioG7HPkvfj_B2GTSL-8ttbBz2ucV6zEVYSqsS97HmabCprAX7xxWCfCm0CDfnK9i-nW1gqDabFVYiPNOWGA_jncFuvAJrJZgDXNUwmSwdq1nGY4whSmWHOLKcGeF6lIDgg?auth=****)
[20:16:19] INFO: Home Assistant Core finish process exit code 256
[20:16:19] INFO: Home Assistant Core finish process received signal 11
2025-12-16 20:16:26.777 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pirateweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:16:26.778 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:16:26.778 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tesla_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:16:26.779 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration playstation_network which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:16:26.779 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:16:26.780 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration pirateweather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:16:26.780 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:16:26.781 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tesla_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:16:26.781 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration playstation_network which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:16:26.781 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-12-16 20:16:27.729 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-12-16 20:16:27.834 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=209 from 2025-12-17 04:15:03.722677)
2025-12-16 20:16:28.557 ERROR (MainThread) [habluetooth.manager] Missing required permissions for Bluetooth management: Missing NET_ADMIN/NET_RAW capabilities for Bluetooth management. Automatic adapter recovery is unavailable. Add NET_ADMIN and NET_RAW capabilities to the container to enable it
E0000 00:00:1765944995.321994      68 alts_credentials.cc:93] ALTS creds ignored. Not running on GCP and untrusted ALTS is not enabled.
2025-12-16 20:16:37.919 WARNING (MainThread) [homeassistant.components.withings] Webhook not registered - https and port 443 is required to register the webhook
2025-12-16 20:16:38.242 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Sony Speaker(http://192.168.86.214:54480/sony)] Unable to connect
2025-12-16 20:16:38.242 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Sony Speaker(http://192.168.86.205:54480/sony)] Unable to connect
2025-12-16 20:16:38.243 WARNING (MainThread) [homeassistant.components.media_player] Platform songpal not ready yet: Unable to do POST request: Cannot connect to host 192.168.86.214:54480 ssl:default [Connect call failed ('192.168.86.214', 54480)]: None; Retrying in background in 30 seconds
2025-12-16 20:16:38.243 WARNING (MainThread) [homeassistant.components.media_player] Platform songpal not ready yet: Unable to do POST request: Cannot connect to host 192.168.86.205:54480 ssl:default [Connect call failed ('192.168.86.205', 54480)]: None; Retrying in background in 30 seconds
2025-12-16 20:17:02.096 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.sonarr_shows exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2025-12-16 20:17:02.919 WARNING (Recorder) [homeassistant.components.recorder.db_schema] State attributes for sensor.sonarr_shows exceed maximum size of 16384 bytes. This can cause database performance issues; Attributes will not be stored
2025-12-16 20:17:04.418 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Sony Speaker(http://192.168.86.205:54480/sony)] Unable to connect
2025-12-16 20:17:04.418 WARNING (MainThread) [homeassistant.components.songpal.media_player] [Sony Speaker(http://192.168.86.214:54480/sony)] Unable to connect
2025-12-16 20:17:12.857 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.kitchen] Error from stream worker: Not Found error opening stream (Server returned 404 Not Found, rtsps://stream-us1-alfa.dropcam.com:443/sdm_live_stream/CiUA2vuxr5N9xGm63q-HnnNSBNC482hcaXl3ZCc5yfOePRILIgifEnEA7cpCCZzcdXu-GVSHUmJnnglWQtbzBTfydnzgsN0CFgpJskVEYR5hqI1HafR7EZk2wySOySJgbbTsG6LQBjdKLZR2QXFdMXNsxGU2CMRAaVaHLTNaMwgu-cd1ktmuzgZBKRoH9BynPzrOkaC8ihpJrw?auth=****)
2025-12-16 20:17:19.758 WARNING (SyncWorker_5) [homeassistant.components.ps4.media_player] PS4 could not be reached
2025-12-16 20:17:33.307 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.kitchen] Error from stream worker: Not Found error opening stream (Server returned 404 Not Found, rtsps://stream-us1-alfa.dropcam.com:443/sdm_live_stream/CiUA2vuxr5N9xGm63q-HnnNSBNC482hcaXl3ZCc5yfOePRILIgifEnEA7cpCCZzcdXu-GVSHUmJnnglWQtbzBTfydnzgsN0CFgpJskVEYR5hqI1HafR7EZk2wySOySJgbbTsG6LQBjdKLZR2QXFdMXNsxGU2CMRAaVaHLTNaMwgu-cd1ktmuzgZBKRoH9BynPzrOkaC8ihpJrw?auth=****)
I also wanted to provide an example of how often HA restarts (I have a NTFY notification that triggers when it starts):
12/16/25, 8:30 PM
Home Assistant Started
12/16/25, 8:28 PM
12/16/25, 8:25 PM
12/16/25, 8:22 PM
12/16/25, 8:20 PM
12/16/25, 8:19 PM
12/16/25, 8:17 PM
12/16/25, 8:15 PM
12/16/25, 8:12 PM
12/16/25, 8:10 PM
12/16/25, 8:09 PM
12/16/25, 8:08 PM
12/16/25, 8:06 PM
12/16/25, 8:04 PM
12/16/25, 8:03 PM
12/16/25, 7:59 PM
12/16/25, 7:57 PM
12/16/25, 7:56 PM
12/16/25, 7:55 PM
12/16/25, 7:53 PM
12/16/25, 7:52 PM
12/16/25, 7:50 PM
12/16/25, 7:49 PM
12/16/25, 7:47 PM
12/16/25, 7:46 PM
12/16/25, 7:44 PM
12/16/25, 7:36 PM
12/16/25, 7:32 PM
Restart in safe mode and see if it is stable. If it is then a third party integration is to blame.
Thanks. sorry for my ignorance, but I couldn’t find how to start in “safe mode” via Docker container. I did see how to do so when running “HA Core” (this thread)
Developer Tools → YAML → Restart → Advanced Options
Thank you! I will give that a try.
