Hey Guys,
I’m facing the following issue:
with the configuration below. Can someone tell me why this error is happening? I know the value 6/1/0 and 6/1/1 are re-occuring but the could not be changed due to limitations in the KNX application.
climate:
- name: 'Klimaatregeling Hal'
setpoint_shift_address: '1/2/2'
setpoint_shift_mode: 'DPT9002'
temperature_step: 0.5
target_temperature_state_address: '1/2/1'
operation_mode_address: '1/2/3'
operation_mode_state_address: '1/2/4'
temperature_address: '6/1/1'
- name: 'Klimaatregeling slaapkamer rechts'
setpoint_shift_address: '1/0/2'
target_temperature_state_address: '1/0/1'
operation_mode_address: '1/0/3'
operation_mode_state_address: '1/0/4'
temperature_address: '6/1/0'
- name: 'Airco Slaapkamer rechts'
on_off_address: '3/0/8'
on_off_state_address: '3/0/0'
min_temp: 5
max_temp: 25
target_temperature_address: '3/0/7'
target_temperature_state_address: '3/0/7'
controller_mode_address: '3/0/9'
controller_mode_state_address: '3/0/1'
- name: 'Airco Slaapkamer links'
on_off_address: '3/1/8'
on_off_state_address: '3/1/0'
min_temp: 5
max_temp: 25
target_temperature_address: '3/1/7'
target_temperature_state_address: '3/1/7'
controller_mode_address: '3/1/9'
controller_mode_state_address: '3/1/1'
- name: 'Airco woonkamer'
on_off_address: '3/2/8'
on_off_state_address: '3/2/0'
min_temp: 5
max_temp: 25
target_temperature_address: '3/2/7'
target_temperature_state_address: '3/2/7'
controller_mode_address: '3/2/9'
controller_mode_state_address: '3/2/1'
