HA KNX communication problem
Hi, maybe someone can help me. I use this blueprint to control my roller shutter actuators. :sunny: Cover Control Automation (CCA) – a comprehensive and highly configurable roller blind blueprint – Blueprints Exchange – Home Assistant Community
I have a separate blueprint for each roller shutter, as recommended. Now I have the following problem. Now in winter, all roller blinds should close after sunset. In principle, this works, but one roller blind does not close. It is NEVER the same one, but always a different one. So I can rule out the settings. I suspect it is because all commands to close are sent to KNX at the same time and then one command is discarded. I can’t imagine any other reason. In the HA log, I can’t find anything unusual at the time of “closing.” This phenomenon did not occur in the summer because different times were specified for the upper and lower floors, so there was no flood of commands. Does anyone here have a similar problem and know a solution?
Greetings
This shouldn’t be the case. Anyway, you can have ETS group monitor running when triggering your automation to check if the telegrams were sent.
Also have a look if your Knx connection is stable - there seem to be some cases of random disconnects lately for some users.
