Firstly, apologies if this has been covered already.
Every Sunday night (between midnight and 1am) my HAOS hangs up. Ive tried connecting a vdu to my Pi3b but nothing displays. The only thing i can do is unplug it and plug it back in again to restart the Pi. This has been happening every Sunday since i installed HA (prob coming up 2 months). Ive wiped the sd card and done a clean install but it hasnt helped. Im very new to HA and have no idea whats causing it. The only thing i found in the Host log around the time of the crash last night was:
21:48:50 homeassistant systemd[1]: started notify NFS peers of a restart
00:15:52 homeassistant systemd-resolved[442]: clock change detected, flushing caches
01:22:23 homeassistant systemd-time-wait-sync[534]: adjtime state 5 status 40 time Mon 2025-03-03 00:15:52.338415 UTC
The last log at 01:22:23 is when I restarted the Pi.
Do you have a backup set to run at that time? Perhaps pi runs out of ram. pi3 is veeery underpowered for modern HA, at least Pi4 is desirable, even better pi5 or (best choice, cheaper than new pi5) used miniPC/ intel nuc or similar. And at minimum 2GB of ram, better 4GB (more doesn’t hurt, or course).
Don’t worry, We’ve all been new to this at some point.
First things first, make sure you have a backup saved off the Pi. You can download it to your PC by clicking the 3 dots next to the backup > Download.
Nothing should break catastrophically, but this way you’re covered.
Next, go to Developer Tools and type in recorder. You should get an option as per below. Make sure the repack options is both ticked on the left and also has the switch toggled on the right, as per below.
So i did as you said. The “apply filter” was checked but the slide wasnt on, everything else was as you explained. Clicked perform action and got a green tick for about 1 second and that was it.
FYI you can monitor the memory use (and other important system resources) with this:
After a crash, restart and have a look a the CPU and memory use history graphs. Did either of them go nuts right before your crash?
Also the file /config/home-assistant.log.1 contains the system log from before the last restart. You can open this with a text editor. It may reveal problems that occurred before the crash.
