HA Logs connection issues with SSL local devices and External Urls
Hey First time Poster,
I am having some issues with HA, Reading into the logs, it’s having trouble connecting with https both local and external, setup on unraid in a VM running HAOS, lan IP is assigned statically, The instance is fully accessible externally using NGINX and domain using SSL certs externally, I am at a blank. Can anyone point me in the right direction?
Logger: pychromecast.socket_client
Source: /usr/local/lib/python3.13/site-packages/pychromecast/socket_client.py:416
First occurred: June 18, 2025 at 2:18:09 AM (37 occurrences)
Last logged: 6:51:42 AM
[Doorbell Group([::ffff:c0a8:270]):32043] Failed to connect to service HostServiceInfo(host=‘[::ffff:c0a8:270]’, port=32043), retrying in 5.0s
[Master Bedroom TV(192.168.2.114):8009] Failed to connect to service HostServiceInfo(host=‘192.168.2.114’, port=8009), retrying in 5.0s
[Lounge room TV(192.168.2.116):8009] Failed to connect to service HostServiceInfo(host=‘192.168.2.116’, port=8009), retrying in 5.0s
[Master bedroom speaker 2(192.168.2.122):8009] Failed to connect to service HostServiceInfo(host=‘192.168.2.122’, port=8009), retrying in 5.0s
[Liam’s Mini(192.168.2.117):8009] Failed to connect to service HostServiceInfo(host=‘192.168.2.117’, port=8009), retrying in 5.0s
Thats an example, I have attached a log for more in-depth
Cheers
Brodie
