Hi Everyone.
I’m having an issue with Matter over Thread devices becoming unavailable in HA, while they continue to work fine in Apple Home. The whole thread network that’s shared credentials in Home Assistant kind of “drops out” from time to time, making devices unavailable.
Setup:
- Mac mini M4 running HA through VMWare Fusion
- Apple HomePod Mini
- Devices are added straight to Home Assistant using the shared thread network (from the HomePod)
Problems:
Devices will initially work fine with Home Assistant, then they will randomly all become unavailable, where they still work through Apple Home.
Home assistant then goes the IPV6 route to the Thread network, where the logs of the Python matter server says:
2026-04-20 17:59:33.113 (MainThread) INFO [matter_server.server.device_controller] <Node:41> Re-Subscription succeeded
2026-04-20 18:02:07.654 (Dummy-2) CHIP_ERROR [chip.native.DMG] Subscription Liveness timeout with SubscriptionID = 0x5516b11c, Peer = 01:0000000000000004
2026-04-20 18:02:07.658 (MainThread) INFO [matter_server.server.device_controller] <Node:4> Subscription failed with CHIP Error 0x00000032: Timeout, resubscription attempt 0
2026-04-20 18:02:08.951 (MainThread) INFO [matter_server.server.device_controller] <Node:4> Re-Subscription succeeded
2026-04-20 18:02:13.394 (Dummy-2) CHIP_ERROR [chip.native.DMG] Subscription Liveness timeout with SubscriptionID = 0xf88fedf9, Peer = 01:0000000000000003
2026-04-20 18:02:13.398 (MainThread) INFO [matter_server.server.device_controller] <Node:3> Subscription failed with CHIP Error 0x00000032: Timeout, resubscription attempt 0
2026-04-20 18:02:14.687 (MainThread) INFO [matter_server.server.device_controller] <Node:3> Re-Subscription succeeded
2026-04-20 18:15:11.756 (Dummy-2) CHIP_ERROR [chip.native.DMG] Subscription Liveness timeout with SubscriptionID = 0x681fe0c9, Peer = 01:0000000000000029
2026-04-20 18:15:11.760 (MainThread) INFO [matter_server.server.device_controller] <Node:41> Subscription failed with CHIP Error 0x00000032: Timeout, resubscription attempt 0
2026-04-20 18:15:11.964 (Dummy-2) CHIP_ERROR [chip.native.IN] SendMessage() to UDP:[fde7:3e28:f487:0:bcfd:af77:42c7:7d0b]:5540 failed: src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
2026-04-20 18:15:11.965 (Dummy-2) CHIP_ERROR [chip.native.-] src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable at src/app/OperationalSessionSetup.cpp:254
2026-04-20 18:15:11.965 (Dummy-2) CHIP_ERROR [chip.native.DMG] Failed to establish CASE for re-subscription with error 'src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable'
2026-04-20 18:15:11.966 (MainThread) INFO [matter_server.server.device_controller] <Node:41> Subscription failed with OS Error 0x02000065: Network is unreachable, resubscription attempt 1
2026-04-20 18:15:17.186 (Dummy-2) CHIP_ERROR [chip.native.IN] SendMessage() to UDP:[fde7:3e28:f487:0:bcfd:af77:42c7:7d0b]:5540 failed: src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
2026-04-20 18:15:17.187 (Dummy-2) CHIP_ERROR [chip.native.-] src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable at src/app/OperationalSessionSetup.cpp:254
2026-04-20 18:15:17.187 (Dummy-2) CHIP_ERROR [chip.native.DMG] Failed to establish CASE for re-subscription with error 'src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable'
2026-04-20 18:15:17.188 (MainThread) INFO [matter_server.server.device_controller] <Node:41> Subscription failed with OS Error 0x02000065: Network is unreachable, resubscription attempt 2
2026-04-20 18:15:17.188 (MainThread) INFO [matter_server.server.device_controller] <Node:41> Marked node as unavailable
2026-04-20 18:15:23.598 (Dummy-2) CHIP_ERROR [chip.native.IN] SendMessage() to UDP:[fde7:3e28:f487:0:bcfd:af77:42c7:7d0b]:5540 failed: src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable
2026-04-20 18:15:23.598 (Dummy-2) CHIP_ERROR [chip.native.-] src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable at src/app/OperationalSessionSetup.cpp:254
2026-04-20 18:15:23.598 (Dummy-2) CHIP_ERROR [chip.native.DMG] Failed to establish CASE for re-subscription with error 'src/inet/UDPEndPointImplSockets.cpp:417: OS Error 0x02000065: Network is unreachable'
2026-04-20 18:15:23.599 (MainThread) INFO [matter_server.server.device_controller] <Node:41> Subscription failed with OS Error 0x02000065: Network is unreachable, resubscription attempt 3
If anyone has any insight on this this would be greatly appreciated, thank you!
