Hi all,
i setup HA on a pi 5 with the ha version 2025.2.4. Basiclie i get it up and running. Also some basic setups are working.
But if i try to install HACS with this documentation and restart the raspberry via settings → hardware, the pi not starting up. To restart the pi, i need to reset the power supply. Then the pi is starting up and rechable via ping. But HA is not running. If i start the oberserver, i got this error messages [1]. Anybody an idea what the problem is and how can i fix it?
Regards
[1]
Home Assistant observer
Supervisor: Disconnected
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[14:42:32] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[14:42:32] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
2025-02-17 14:42:34.257 INFO (MainThread) [__main__] Initializing Supervisor setup
2025-02-17 15:42:34.296 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi5-64
2025-02-17 15:42:34.299 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2025.02.1
2025-02-17 15:42:34.300 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2025-02-17 15:42:34.492 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.12.3']
2025-02-17 15:42:34.950 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2025-02-17 15:42:34.951 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-17 15:42:34.952 INFO (MainThread) [__main__] Setting up Supervisor
2025-02-17 15:42:35.090 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2025-02-17 15:42:35.132 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2025-02-17 15:42:35.133 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2025-02-17 15:42:35.133 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2025-02-17 15:42:35.134 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2025-02-17 15:42:35.134 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2025-02-17 15:42:35.135 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2025-02-17 15:42:35.136 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2025-02-17 15:42:35.136 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2025-02-17 15:42:35.136 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2025-02-17 15:42:35.136 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2025-02-17 15:42:35.295 INFO (MainThread) [supervisor.host.services] Updating service information
2025-02-17 15:42:35.300 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-02-17 15:42:35.433 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-02-17 15:42:35.464 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2025-02-17 15:42:35.501 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2025-02-17 15:42:35.501 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2025-02-17 15:42:35.959 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.09.0
2025-02-17 15:42:35.978 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.12.0
2025-02-17 15:42:35.988 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2025-02-17 15:42:35.994 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
2025-02-17 15:42:36.007 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
2025-02-17 15:42:36.019 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
2025-02-17 15:42:36.078 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
2025-02-17 15:42:36.082 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi5-64-homeassistant with version landingpage
2025-02-17 15:42:36.090 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
2025-02-17 15:42:36.117 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 14.2 / BootSlot A
2025-02-17 15:42:36.224 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2025-02-17 15:42:36.225 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
2025-02-17 15:42:36.225 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d5369777 repository
2025-02-17 15:42:36.226 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
2025-02-17 15:42:36.398 INFO (MainThread) [supervisor.store] Loading add-ons from store: 81 all - 81 new - 0 remove
2025-02-17 15:42:36.414 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2025-02-17 15:42:36.427 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
2025-02-17 15:42:36.427 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2025-02-17 15:42:36.427 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2025-02-17 15:42:36.427 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2025-02-17 15:42:36.427 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-02-17 15:42:36.427 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2025-02-17 15:42:36.427 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-02-17 15:42:36.427 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2025-02-17 15:42:36.428 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-02-17 15:42:36.428 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-02-17 15:42:36.428 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-17 15:42:36.428 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2025-02-17 15:42:36.429 INFO (MainThread) [__main__] Running Supervisor
2025-02-17 15:42:36.464 INFO (MainThread) [supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
2025-02-17 15:42:36.471 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2025-02-17 15:42:36.476 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
2025-02-17 15:42:36.476 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
2025-02-17 15:42:36.479 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
2025-02-17 15:42:36.479 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
2025-02-17 15:42:36.485 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2025-02-17 15:42:36.485 INFO (MainThread) [supervisor.core] Supervisor is up and running
2025-02-17 15:42:36.486 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
2025-02-17 15:42:36.486 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi5-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2025.2.4
2025-02-17 15:42:36.486 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi5-64-homeassistant with tag 2025.2.4.
2025-02-17 15:42:36.486 INFO (MainThread) [supervisor.host.info] Updating local host information
2025-02-17 15:42:36.488 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-02-17 15:42:36.488 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-02-17 15:42:36.489 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-02-17 15:42:36.489 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-02-17 15:42:36.489 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-02-17 15:42:36.494 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-02-17 15:42:36.495 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-02-17 15:42:36.505 INFO (MainThread) [supervisor.host.services] Updating service information
2025-02-17 15:42:36.509 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-02-17 15:42:36.538 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-02-17 15:42:36.538 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-02-17 15:42:36.571 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-02-17 15:42:36.571 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2025-02-17 15:42:36.571 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2025-02-17 15:42:36.572 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2025-02-17 15:42:36.572 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-02-17 15:42:36.572 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-02-17 15:42:36.572 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-02-17 15:42:36.576 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-02-17 15:42:36.628 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-17 15:42:36.628 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-02-17 15:42:36.628 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-02-17 15:44:32.060 INFO (SyncWorker_4) [supervisor.docker.manager] Stopping homeassistant application
2025-02-17 15:44:51.698 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning homeassistant application
2025-02-17 15:44:51.717 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant docker now installed
2025-02-17 15:44:51.773 INFO (MainThread) [supervisor.homeassistant.core] Starting Home Assistant
2025-02-17 15:44:51.784 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2025-02-17 15:44:52.378 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi5-64-homeassistant with version 2025.2.4
2025-02-17 15:44:52.379 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-02-17 15:44:58.301 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-02-17 15:44:58.363 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-17 15:45:02.408 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-02-17 15:45:02.414 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2025-02-17 15:45:02.415 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2025-02-17 15:45:02.433 INFO (SyncWorker_7) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/raspberrypi5-64-homeassistant:landingpage']
2025-02-17 15:46:47.564 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-02-17 15:46:47.614 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-17 15:46:51.637 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-02-17 15:46:51.689 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-02-17 15:51:45.892 INFO (MainThread) [supervisor.addons.addon] No core_samba addon Docker image homeassistant/aarch64-addon-samba found
2025-02-17 15:51:45.893 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-samba with tag 12.4.0.
2025-02-17 15:51:51.857 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/core_samba
2025-02-17 15:51:51.858 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-samba with tag 12.4.0.
2025-02-17 15:51:53.106 INFO (MainThread) [supervisor.addons.manager] Add-on 'core_samba' successfully installed
2025-02-17 15:52:21.990 INFO (MainThread) [supervisor.addons.addon] No a0d7b954_nodered addon Docker image ghcr.io/hassio-addons/node-red/aarch64 found
2025-02-17 15:52:21.990 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/hassio-addons/node-red/aarch64 with tag 19.0.1.
2025-02-17 15:52:44.292 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/a0d7b954_nodered
2025-02-17 15:52:44.293 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/hassio-addons/node-red/aarch64 with tag 19.0.1.
2025-02-17 15:52:44.904 INFO (MainThread) [supervisor.addons.manager] Add-on 'a0d7b954_nodered' successfully installed
2025-02-17 15:52:47.406 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for a0d7b954_nodered
2025-02-17 15:53:43.611 INFO (SyncWorker_1) [supervisor.addons.addon] Creating Home Assistant add-on config folder /data/addon_configs/a0d7b954_nodered
2025-02-17 15:53:44.027 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/node-red/aarch64 with version 19.0.1
2025-02-17 15:54:07.987 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_a0d7b954_nodered application
2025-02-17 15:54:08.297 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/node-red/aarch64 with version 19.0.1
2025-02-17 15:54:16.374 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2025-02-17 15:54:16.382 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
2025-02-17 15:54:16.385 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
2025-02-17 15:54:33.116 INFO (MainThread) [supervisor.addons.addon] No a0d7b954_ssh addon Docker image ghcr.io/hassio-addons/ssh/aarch64 found
2025-02-17 15:54:33.117 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/hassio-addons/ssh/aarch64 with tag 20.0.0.
2025-02-17 15:54:50.733 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/a0d7b954_ssh
2025-02-17 15:54:50.734 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/hassio-addons/ssh/aarch64 with tag 20.0.0.
2025-02-17 15:54:51.305 INFO (MainThread) [supervisor.addons.manager] Add-on 'a0d7b954_ssh' successfully installed
2025-02-17 15:55:20.091 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/ssh/aarch64 with version 20.0.0
2025-02-17 15:55:52.671 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_a0d7b954_ssh application
2025-02-17 15:55:53.005 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/ssh/aarch64 with version 20.0.0
2025-02-17 15:57:02.636 INFO (MainThread) [supervisor.host.control] Set hostname Moekki-HA
2025-02-17 15:57:06.427 INFO (MainThread) [supervisor.plugins.dns] Restarting CoreDNS plugin
2025-02-17 15:57:06.432 INFO (SyncWorker_3) [supervisor.docker.manager] Restarting hassio_dns
2025-02-17 15:57:06.438 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-02-17 15:58:19.992 INFO (MainThread) [supervisor.host.control] Initialize host reboot using logind
2025-02-17 15:58:19.993 INFO (MainThread) [supervisor.addons.manager] Phase 'application' stopping 1 add-ons
2025-02-17 15:58:19.998 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping addon_a0d7b954_nodered application
2025-02-17 15:58:20.103 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for a0d7b954_nodered closed
2025-02-17 15:58:23.408 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_a0d7b954_nodered application
2025-02-17 15:58:23.434 INFO (SyncWorker_7) [supervisor.docker.manager] Stopping homeassistant application
2025-02-17 15:58:38.376 INFO (MainThread) [supervisor.addons.manager] Phase 'services' stopping 1 add-ons
2025-02-17 15:58:38.382 INFO (SyncWorker_6) [supervisor.docker.manager] Stopping addon_a0d7b954_ssh application
2025-02-17 15:58:41.897 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_a0d7b954_ssh application
2025-02-17 15:58:41.969 INFO (MainThread) [supervisor.addons.manager] Phase 'system' stopping 0 add-ons
2025-02-17 15:58:41.969 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' stopping 0 add-ons
2025-02-17 15:58:41.969 INFO (MainThread) [supervisor.plugins.cli] Stopping cli plugin
2025-02-17 15:58:41.972 INFO (SyncWorker_4) [supervisor.docker.manager] Stopping hassio_cli application
2025-02-17 15:58:45.420 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning hassio_cli application
2025-02-17 15:58:45.488 INFO (MainThread) [supervisor.plugins.dns] Stopping CoreDNS plugin
2025-02-17 15:58:45.491 INFO (SyncWorker_5) [supervisor.docker.manager] Stopping hassio_dns application
2025-02-17 15:58:49.059 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning hassio_dns application
2025-02-17 15:58:49.127 INFO (MainThread) [supervisor.plugins.audio] Stopping Audio plugin
2025-02-17 15:58:49.130 INFO (SyncWorker_3) [supervisor.docker.manager] Stopping hassio_audio application
2025-02-17 15:58:52.641 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning hassio_audio application
2025-02-17 15:58:52.710 INFO (MainThread) [supervisor.plugins.multicast] Stopping Multicast plugin
2025-02-17 15:58:52.713 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping hassio_multicast application
2025-02-17 15:58:56.016 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_multicast application
2025-02-17 15:58:56.052 ERROR (MainThread) [aiohttp.server] Error handling request from 172.30.32.1
File "/usr/local/lib/python3.13/site-packages/aiohttp/client_proto.py", line 92, in connection_lost
uncompleted = self._parser.feed_eof()
File "aiohttp/_http_parser.pyx", line 508, in aiohttp._http_parser.HttpParser.feed_eof
aiohttp.http_exceptions.TransferEncodingError: 400, message:
Not enough data for satisfy transfer length header.
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
return await handler(request)
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 199, in block_bad_requests
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 215, in system_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 285, in token_validation
File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 298, in core_proxy
File "/usr/src/supervisor/supervisor/api/utils.py", line 108, in wrap_api
msg_data = await method(api, *args, **kwargs)
File "/usr/src/supervisor/supervisor/api/__init__.py", line 529, in get_addon_logs
return await self._api_host.advanced_logs(request, *args, **kwargs)
File "/usr/src/supervisor/supervisor/api/host.py", line 279, in advanced_logs
return await self.advanced_logs_handler(request, identifier, follow)
File "/usr/src/supervisor/supervisor/api/host.py", line 257, in advanced_logs_handler
async for cursor, line in journal_logs_reader(resp, log_formatter):
...<9 lines>...
await response.write(line.encode("utf-8") + b"\n")
File "/usr/src/supervisor/supervisor/utils/systemd_journal.py", line 80, in journal_logs_reader
line = await resp.content.readuntil(b"\n")
File "/usr/local/lib/python3.13/site-packages/aiohttp/streams.py", line 386, in readuntil
await self._wait("readuntil")
File "/usr/local/lib/python3.13/site-packages/aiohttp/streams.py", line 347, in _wait
await waiter
aiohttp.client_exceptions.ClientPayloadError: Response payload is not completed:
2025-02-17 15:58:56.057 ERROR (MainThread) [aiohttp.server] Error handling request from 172.30.32.1
...<9 lines>...
await waiter
s6-rc: info: service legacy-services: stopping
[14:58:56] INFO: Watchdog restart after closing
2025-02-17 15:58:56.741 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
2025-02-17 15:58:56.742 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
2025-02-17 15:58:56.742 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
2025-02-17 15:58:56.749 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
2025-02-17 15:58:56.753 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
2025-02-17 15:58:56.754 INFO (MainThread) [supervisor.core] Supervisor is down - 0
2025-02-17 15:58:56.755 INFO (MainThread) [__main__] Closing Supervisor
[14:58:57] WARNING: Halt Supervisor
