Hi
This were all working ok albeit a bit slow, and now HA wont start.
core-ssh:~# hassio supervisor logs
17-10-24 21:46:48 INFO (SyncWorker_13) [hassio.dock.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
17-10-24 21:46:48 ERROR (SyncWorker_13) [hassio.dock] Can’t create container from homeassistant -> 409 Client Error: Conflict (“Conflict. The container name “/homeassistant” is already in use by container “7d30fe6964f64aac008a42345234523c7f9d57345234503ac1d2223453455a16d0”. You have to remove (or rename) that container to be able to reuse that name.”)
17-10-24 21:47:02 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
Any suggestions on how I might fix this or is it terminal?
