Followed the directions for getting setup in docker on windows 10 and the container does not have an ip address nor does it expose a port. This makes sense because you are telling us to use the --net=host and therefore the container should be using the hosts ip and ports.
docker run --init -d --name="home-assistant" -e "TZ=America/Los_Angeles" -v /config:/config --net=host homeassistant/home-assistant:stable
localhost:8123/ - doesn’t work
127.0.0.1:8123/ - doesn’t work
192.168.88.219:8123/ - doesn’t work (my machine’s ip)
If I run the container with a standard bridge network then the UI loads but the application will not discover any devices since its on a private network.
docker run --init -d --name="home-assistant" -e "TZ=America/Los_Angeles" -v /config:/config homeassistant/home-assistant:stable
How do I tell HA via the configuration what network it should be using to discover devices when running in a bridged network?
