HA on docker rootless stopped working after regular Ubuntu 24.04 upgrade
Hi All,
I had HA running in my computer with Ubuntu 24.04 on docker rootless with no issue.
Yesterday, Ubuntu did a regular packages upgrade and I was asked to reboot. After doing so, I cannot access my HA installation.
I tried to update HA just in case:
docker pull ghcr.io/home-assistant/home-assistant:stable
docker stop homeassistant
docker rm homeassistant
docker run -d --name homeassistant --restart=unless-stopped -e TZ=Europe/Madrid -v <my_home_folder:/config> -p 8123:8123 ghcr.io/home-assistant/home-assistant:stable
And got this message:
docker: Error response from daemon: failed to set up container networking: driver failed programming external connectivity on endpoint homeassistant (4771949111bbac8046239ca41d989c58a70e5102e7984defc06978c75510a7c1): failed to bind host port 10.0.2.100:8123/tcp: address already in use
These were the last updated Ubuntu packages that required a reboot:
$ grep "status installed" /var/log/dpkg.log*
/var/log/dpkg.log:2025-11-22 06:33:05 status installed linux-tools-6.14.0-34-generic:amd64 6.14.0-34.34~24.04.1
/var/log/dpkg.log:2025-11-22 06:33:05 status installed linux-hwe-6.14-tools-6.14.0-34:amd64 6.14.0-34.34~24.04.1
/var/log/dpkg.log:2025-11-22 06:33:07 status installed linux-image-6.14.0-34-generic:amd64 6.14.0-34.34~24.04.1
/var/log/dpkg.log:2025-11-22 06:33:11 status installed linux-modules-extra-6.14.0-34-generic:amd64 6.14.0-34.34~24.04.1
/var/log/dpkg.log:2025-11-22 06:33:12 status installed linux-modules-6.14.0-34-generic:amd64 6.14.0-34.34~24.04.1
/var/log/dpkg.log:2025-11-22 06:33:14 status installed linux-headers-6.14.0-34-generic:amd64 6.14.0-34.34~24.04.1
/var/log/dpkg.log:2025-11-22 06:33:15 status installed linux-hwe-6.14-headers-6.14.0-34:all 6.14.0-34.34~24.04.1
/var/log/dpkg.log:2025-11-22 09:48:06 status installed xdg-dbus-proxy:amd64 0.1.5-1ubuntu0.1
/var/log/dpkg.log:2025-11-22 09:48:06 status installed desktop-file-utils:amd64 0.27-2build1
/var/log/dpkg.log:2025-11-22 09:48:06 status installed hicolor-icon-theme:all 0.17-2
/var/log/dpkg.log:2025-11-22 09:48:06 status installed gnome-menus:amd64 3.36.0-1.1ubuntu3
/var/log/dpkg.log:2025-11-22 09:48:06 status installed libc-bin:amd64 2.39-0ubuntu8.6
/var/log/dpkg.log:2025-11-22 09:48:07 status installed man-db:amd64 2.12.0-4build2
/var/log/dpkg.log:2025-11-22 09:48:07 status installed libgtk-4-common:all 4.14.5+ds-0ubuntu0.6
/var/log/dpkg.log:2025-11-22 09:48:07 status installed gnome-shell-common:all 46.0-0ubuntu6~24.04.11
/var/log/dpkg.log:2025-11-22 09:48:07 status installed libglib2.0-0t64:amd64 2.80.0-6ubuntu3.4
/var/log/dpkg.log:2025-11-22 09:48:07 status installed libgtk-4-1:amd64 4.14.5+ds-0ubuntu0.6
/var/log/dpkg.log:2025-11-22 09:48:07 status installed libgtk-4-bin:amd64 4.14.5+ds-0ubuntu0.6
/var/log/dpkg.log:2025-11-22 09:48:07 status installed gir1.2-gtk-4.0:amd64 4.14.5+ds-0ubuntu0.6
/var/log/dpkg.log:2025-11-22 09:48:07 status installed gnome-shell:amd64 46.0-0ubuntu6~24.04.11
/var/log/dpkg.log:2025-11-22 09:48:07 status installed libgtk-4-media-gstreamer:amd64 4.14.5+ds-0ubuntu0.6
/var/log/dpkg.log:2025-11-22 09:48:07 status installed libc-bin:amd64 2.39-0ubuntu8.6
Any idea?
Thanks in advance.
Best Regards.
Jordi.
Shut Down host
Restart
I sometimes get this after restarts but I forget detailed cause. I just know full shutdown (not restart) it fast resolution
Docker ps
Is another container running? What’s using the port? This is why HA not starting
Rebooting would just prevent us from proper troubleshooting.Share the result of these
docker ps
ss -lntp | grep "8123"
Note that this is not necessarily supported.
I’d recommend you use a compose file.
Nothing returned on both commands:
It seems to be a problem with the latest docker-rootless update.
I found exactly the same issue in this post:
Issue solved with docker 29.1.2
