HA OS installation and network settings
Good day!
I’ve encountered a problem. I have a network that doesn’t have a DHCP server. I have a Proxmox server, on which I’m trying to install an HA server using a script. The problem is, I don’t understand how to configure the network card settings before starting the virtual machine. I’m trying to correct the network settings after starting the server using nmcli, but the server is already configuring its initial startup and is encountering errors due to missing network settings (internet). Is there a way to properly configure it?
P.S. The network settings are missing before the initial startup…
what about reserving an ip in your router based on the mac address?
There is no DHCP server on the network. Each IP address is entered manually.
