HA OS Stuck in VM Boot
Everytime I restart the VM running HA I seem to get stuck in emergency mode and have to press Control-D to continue with the boot process but once its booted, everything “appears” to be working properly and I have no further issues until I attempt to reboot the VM again.
Here is the error screen:
When I go into Config > Settings > Log > View Full HA Log Im not seeing anything obvious because some plugins slow to respond…etc. And if I do the restart within HA it reboots just fine. Its only when the VM is starting that it seems to generate this error which wouldn’t be a problem except I have to TeamViewer into the host PC and press Control-D to resume the boot process. Recorder, LoveLace, Dashboards, everything appears to be working as expected so this is stumping me.
VirtualBox 6.1.28
Home Assistant OS 7.1
supervisor-2021.12.2
core-2021.12.7
Did this start with the HAOS 7.1 update?
I did just update today, however I noticed this problem started about a week ago so would include the previous build.
