CORE LOG (FULL):
2022-08-09 17:08:09.458 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration wyzeapi which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-09 17:08:09.463 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration wyzesense which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-09 17:08:09.467 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-09 17:08:09.471 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alarmdotcomajax which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-09 17:08:09.471 ERROR (SyncWorker_0) [homeassistant.loader] The custom integration 'alarmdotcomajax' does not have a version key in the manifest file and was blocked from loading. See https://developers.home-assistant.io/blog/2021/01/29/custom-integration-changes#versions for more details
2022-08-09 17:08:09.484 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-09 17:08:09.488 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration reolink_dev which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-09 17:08:15.546 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2022-08-09 17:08:15.754 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=42 from 2022-08-09 19:04:35.416372)
2022-08-09 17:09:14.938 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio
2022-08-09 17:10:10.495 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package wyzesense==0.0.4: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa79cc9a0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa79cc310>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa79cc640>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa79cceb0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa79ccd30>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa79ccd00>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa79cc250>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa79cc0a0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa79cd7e0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa79cd960>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
ERROR: Could not find a version that satisfies the requirement wyzesense==0.0.4 (from versions: none)
ERROR: No matching distribution found for wyzesense==0.0.4
WARNING: There was an error checking the latest version of pip.
2022-08-09 17:10:15.132 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio
2022-08-09 17:11:15.249 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio
2022-08-09 17:11:15.870 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for stage 1 - moving forward
2022-08-09 17:11:52.306 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package wyzesense==0.0.4: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f88d4c5b0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f88d4c7c0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f88d4ca30>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f88d4ccd0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f88d4cc40>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f88d4d330>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f88d4d5d0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f88d4d780>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f88d4d930>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f88d4dae0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
2022-08-09 17:12:17.693 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio, raspberry_pi
2022-08-09 17:13:17.786 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio, raspberry_pi
2022-08-09 17:13:30.063 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package wyzesense==0.0.4: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f835a2890>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f835a1ae0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f835a07f0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f835a38e0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f835a23e0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f835a1570>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f835a3e80>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f835a33d0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f835a1810>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f835a1b10>: Failed to establish a new connection: [Errno -3] Try again')': /simple/wyzesense/
2022-08-09 17:14:18.462 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio, raspberry_pi
2022-08-09 17:15:12.074 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package retry==0.9.2: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa2d94430>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa2d94760>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa2d941f0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa2d96f50>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa2d95a80>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa2d97c40>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa2d97a90>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa2d974f0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa2d964a0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fa2d972b0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
ERROR: Could not find a version that satisfies the requirement retry==0.9.2 (from versions: none)
ERROR: No matching distribution found for retry==0.9.2
2022-08-09 17:15:18.560 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio, raspberry_pi
2022-08-09 17:16:18.659 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio, raspberry_pi
2022-08-09 17:16:49.749 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package retry==0.9.2: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f95218880>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f95218b80>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f9521a230>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f95219690>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f95218280>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f95218ca0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f95218190>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f95218040>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f95218fa0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7f95219840>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
2022-08-09 17:17:18.760 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio, raspberry_pi
2022-08-09 17:18:18.860 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio, raspberry_pi
2022-08-09 17:18:27.568 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package retry==0.9.2: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fb70f8040>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fb70f99f0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fb70f8ee0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fb70fb8e0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fb70fa2f0>: Failed to establish a new connection: [Errno -3] Try again')': /musllinux/
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fb70fb190>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fb70f93c0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fb70fa4a0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fb70fb3d0>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0x7fb70f9840>: Failed to establish a new connection: [Errno -3] Try again')': /simple/retry/
2022-08-09 17:18:27.572 ERROR (MainThread) [homeassistant.config] Platform error: binary_sensor - Requirements for wyzesense not found: ['wyzesense==0.0.4', 'retry==0.9.2'].
2022-08-09 17:18:31.630 WARNING (MainThread) [homeassistant.config_entries] Config entry '65" TCL Roku TV' for roku integration not ready yet: Invalid response from API: Error occurred while communicating with device; Retrying in background
2022-08-09 17:18:33.809 ERROR (SyncWorker_4) [pyecobee] Error connecting to ecobee while attempting to refresh tokens. Possible connectivity outage.
HTTPSConnectionPool(host='api.ecobee.com', port=443): Max retries exceeded with url: /token?grant_type=refresh_token&refresh_token=E58a0nav0TowP1fRpHF2EvLkgie0oMiz&client_id=03DzYEBpCprmdH0qN3n5TorjCqafkg2N (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f97de33d0>: Failed to establish a new connection: [Errno -3] Try again'))
2022-08-09 17:18:47.822 WARNING (MainThread) [homeassistant.setup] Setup of flux_led is taking over 10 seconds.
2022-08-09 17:18:47.851 WARNING (MainThread) [homeassistant.setup] Setup of automation is taking over 10 seconds.
2022-08-09 17:18:47.866 ERROR (MainThread) [homeassistant.components.ecobee] Error refreshing ecobee tokens
2022-08-09 17:18:47.895 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2022-08-09 17:18:47.931 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_samba:
2022-08-09 17:18:47.942 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Roku Player' for roku integration not ready yet: Invalid response from API: Timeout occurred while connecting to device; Retrying in background
2022-08-09 17:18:47.947 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/stats request
2022-08-09 17:18:47.956 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_deconz:
2022-08-09 17:18:47.958 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_ssh/stats request
2022-08-09 17:18:47.960 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_ssh:
2022-08-09 17:18:47.971 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/03d23610_dasshio/stats request
2022-08-09 17:18:47.990 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for 03d23610_dasshio:
2022-08-09 17:18:47.992 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2022-08-09 17:18:47.994 WARNING (MainThread) [homeassistant.components.hassio] Could not fetch stats for core_mosquitto:
2022-08-09 17:18:48.038 ERROR (MainThread) [homeassistant.components.deconz] Error connecting to deCONZ gateway at core-deconz
2022-08-09 17:18:48.047 WARNING (MainThread) [homeassistant.config_entries] Config entry '00212E0596FC' for deconz integration not ready yet; Retrying in background
2022-08-09 17:18:48.783 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
