HA reboot / unaccesible loop
Hi, 2 weeks from now HA suddently stopped working. and everything in house is mad working… things going on and off on random hours…
I’m unable to access HA due to it becomes unaccesible 95% of time. There are only few minutes rndomly when it can be available but, it last like 2 minutes, and then it goes off again.
I dont now what to do. I cant connect to restore a backup, or to see whats ahappening.
Observer says this:
Supervisor: Connected
Support: Processing…
Health: Processing…
2025-05-08 10:24:21.714 INFO (MainThread) [supervisor.backups.manager] Found 38 backup files
2025-05-08 10:24:21.851 INFO (MainThread) [supervisor.discovery] Loaded 1 messages
2025-05-08 10:24:21.852 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2025-05-08 10:24:21.852 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2025-05-08 10:24:21.853 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-05-08 10:24:21.853 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2025-05-08 10:24:21.854 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-05-08 10:24:21.854 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2025-05-08 10:24:21.855 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-05-08 10:24:21.855 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-05-08 10:24:21.856 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-05-08 10:24:21.856 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not running - setup
2025-05-08 10:24:21.857 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-05-08 10:24:21.858 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-05-08 10:24:21.860 INFO (MainThread) [main] Running Supervisor
2025-05-08 10:24:21.990 INFO (MainThread) [supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
2025-05-08 10:24:22.068 INFO (MainThread) [supervisor.addons.manager] Phase ‘initialize’ starting 0 add-ons
2025-05-08 10:24:22.091 INFO (MainThread) [supervisor.addons.manager] Phase ‘system’ starting 0 add-ons
2025-05-08 10:24:22.091 INFO (MainThread) [supervisor.addons.manager] Phase ‘services’ starting 3 add-ons
2025-05-08 10:24:22.215 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_core_matter_server application
2025-05-08 10:24:23.331 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-matter-server with version 6.6.0
2025-05-08 10:24:23.463 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_a0d7b954_tailscale application
2025-05-08 10:24:25.225 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on Package tailscale/aarch64 · GitHub with version 0.24.0
2025-05-08 10:24:25.447 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_a0d7b954_ssh application
2025-05-08 10:24:27.587 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on Package ssh/aarch64 · GitHub with version 19.0.0
2025-05-08 10:24:31.076 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from a0d7b954_tailscale
2025-05-08 10:24:31.366 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/enu1u1/info access from a0d7b954_tailscale
2025-05-08 10:24:31.631 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/wlan0/info access from a0d7b954_tailscale
2025-05-08 10:24:32.651 INFO (MainThread) [supervisor.core] Start Home Assistant Core
2025-05-08 10:24:32.821 INFO (SyncWorker_5) [supervisor.docker.manager] Starting homeassistant
2025-05-08 10:24:33.775 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-05-08 10:24:41.971 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_matter_server
2025-05-08 10:27:34.589 ERROR (MainThread) [supervisor.homeassistant.core] No Home Assistant Core response, assuming a fatal startup error
2025-05-08 10:27:34.590 ERROR (MainThread) [supervisor.core] Can’t start Home Assistant Core - rebuiling
2025-05-08 10:27:34.604 INFO (SyncWorker_3) [supervisor.docker.manager] Stopping homeassistant application
2025-05-08 10:28:24.876 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning homeassistant application
2025-05-08 10:28:25.821 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2025-05-08 10:28:26.900 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant Package raspberrypi3-64-homeassistant · GitHub with version 2024.11.1
2025-05-08 10:28:26.902 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-05-08 10:29:10.068 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state startup
2025-05-08 10:29:10.074 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-05-08 10:29:12.221 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-05-08 10:29:12.253 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state=‘NOT_RUNNING’, offline_db_migration=False)
2025-05-08 10:29:59.259 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_core_matter_server application
2025-05-08 10:30:06.188 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-matter-server with version 6.6.0
2025-05-08 10:30:20.670 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_matter_server
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[08:56:03] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[08:56:03] INFO: Starting local supervisor watchdog…
2025-05-08 08:56:11.952 INFO (MainThread) [main] Initializing Supervisor setup
2025-05-08 08:56:12.304 INFO (MainThread) [supervisor.coresys] Setting up coresys for machine: raspberrypi3-64
2025-05-08 10:56:12.326 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor Package aarch64-hassio-supervisor · GitHub with version 2025.04.1
2025-05-08 10:56:12.435 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2025-05-08 10:56:12.445 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-05-08 10:56:12.447 INFO (MainThread) [main] Setting up Supervisor
2025-05-08 10:56:12.689 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2025-05-08 10:56:12.915 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2025-05-08 10:56:12.920 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2025-05-08 10:56:12.921 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2025-05-08 10:56:12.923 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2025-05-08 10:56:12.926 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2025-05-08 10:56:12.929 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2025-05-08 10:56:12.931 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2025-05-08 10:56:12.933 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2025-05-08 10:56:12.934 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2025-05-08 10:56:12.935 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2025-05-08 10:56:13.138 ERROR (MainThread) [supervisor.dbus.agent] Can’t load OS Agent dbus interface io.hass.os /io/hass/os/Config/Swap: D-Bus object /io/hass/os/Config/Swap is not usable, introspection is missing required properties interface
2025-05-08 10:56:13.787 INFO (MainThread) [supervisor.host.services] Updating service information
2025-05-08 10:56:13.808 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-05-08 10:56:13.825 WARNING (SyncWorker_2) [supervisor.host.sound] Can’t update PulseAudio data: Failed to connect to pulseaudio server
2025-05-08 10:56:15.885 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-05-08 10:56:16.081 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
2025-05-08 10:56:16.121 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2025-05-08 10:56:16.122 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2025-05-08 10:56:16.351 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-cli · GitHub with version 2025.04.0
2025-05-08 10:56:16.417 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2025-05-08 10:56:16.441 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning hassio_cli application
2025-05-08 10:56:18.125 INFO (MainThread) [supervisor.docker.cli] Starting CLI Package aarch64-hassio-cli · GitHub with version 2025.04.0 - 172.30.32.5
2025-05-08 10:56:18.194 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-dns · GitHub with version 2025.02.0
2025-05-08 10:56:18.307 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2025-05-08 10:56:18.348 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning hassio_dns application
2025-05-08 10:56:20.282 INFO (MainThread) [supervisor.docker.dns] Starting DNS Package aarch64-hassio-dns · GitHub with version 2025.02.0 - 172.30.32.3
2025-05-08 10:56:20.287 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2025-05-08 10:56:20.317 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-audio · GitHub with version 2025.02.0
2025-05-08 10:56:20.376 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2025-05-08 10:56:20.426 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning hassio_audio application
2025-05-08 10:56:22.333 INFO (MainThread) [supervisor.docker.audio] Starting Audio Package aarch64-hassio-audio · GitHub with version 2025.02.0 - 172.30.32.4
2025-05-08 10:56:22.350 INFO (MainThread) [supervisor.docker.interface] Attaching to ghc
Help me please…
