HA - RGB CCT working Remote Controll
Good evening from Austria,
I just finished my House Lighting Setup with lots of RGB CCT Stripes and Lamps, most of them connected via Zigbee RGB Controller and some of the over Matter.
Each RGB Controller ( Miboxer 3 in 1 LED FUT037Z+) is included via Zigbee2mqtt, each of that Controller is also connected by wifi to a single RGB CCT Remote so every stripe could be separated controlled by a remote.
But now i want to use the power of HA and combine some of the Controller to 1 virtual Device, that’s no problem with the helper function and working on ha dashboard.
At least i want to get a remote to control those helper led lights, thats the point.
Tested 2 zigbee remotes now, one time a miboxer and now I’ve got a Tint remote, thy are working but the dimmer, color picker, light temperature are recognized as one button… thats bad.
Does anyone have the same problem and got a working solution? I dont care about the brand, i only want a remote control that could be connected to ha and could do that job, additional point woould be more lights/groups by buttons to switch in the remote.
Hope some of you got it and could help me with that.
Thx and great evening
