I have posted this similar problem earlier this year and have yet to find a solution. No matter by which means I try to stop HA server it almost always does a restart. I have used the web interface config/server_control/sop option as well as command ha core stop . I may have to repeat this 5-10 times before the server actually stops.
I can’t be the only person having this problem, am I?
This tenacity seems like a desirable feature and maybe a built-in feature of HA.
Personally once I get something to start working with HA, I expect it to keep working in perpetuity and any disruptions even ones as major as firmware upgrade or OEMs related decisions just comes as “annoying”.
I view this is as the “tenacity” factor of automation without which “automation” is significantly less valuable in terms of reliability.
Have you considered plugging the HA machine to a smart switch like Kasa which gives you the ability to turn the HA machine on/off as you see fit using your phone app?
The problem is I need HA to stop but keep the PI up and running so I can copy/edit/replace/etc HA files.
For example, yesterday my Smartthings integration was lost and I had to reconnect. Once done, all my ST area assignments within HA are gone. I need to stop HA and copy a backup of /storage/core.device_registry file. If I do that while HA is running, the recently copied backup file will be overwritten by HA when it restarts. That is just one example where I need make changes without HA running.
Just to be clear, I have not actually had problems shutting down the PI either with sudo halt or ha host shutdown Shutting down HA while keeping the PI up and running is my issue.
