Tino
February 1, 2018, 9:39pm
1
I did a fresh install of Hassbian and played a little bit around. Today I realised that my Home isn´t shown at the right location in the map. Please have a look at my screenshot. My mobile phone is at home, the correct location in the map!
How could I fix it?
Thank you and sorry for my bad English…
Did you set the latitude and longitude in your config file?
Tino
February 1, 2018, 10:04pm
3
Hi Lars!
LarsNorgaard:
HA did this automatic, but I changed both by myself. But nothing happened
What are you using to track the phone?
Also set up your zones for future automations:
Tino:
probably based on IP geolocation, since there isn’t an actual GPS in your device running Home Assistant.
You should probably use the exact coordinates since those numbers actually mean a lot.
Tino
February 1, 2018, 10:51pm
7
thanks for the advice! Now I created zones in my configuration.yaml, but still the same problem. I’ve got the HA iOS App
namadori
(Namadori)
February 2, 2018, 9:03pm
8
Have you created a zone called “Home” with the correct coordinates?
Tino
February 3, 2018, 12:17am
9
I don’t know why, but now it´s working ! Thanks to all
