Hello everyone,
I bought the EN14604 Decade Battery TUYA Connected Smoke Alarm through Tuya. It works with Wifi and RF433. When one smoke detector is alarmed, the others are also alarmed. Warning notifications also come via Tuya, but the homeassistant is not triggered in any way. I exposed the sensor to smoke for about 8 minutes, but still no homeassistant notification came. I made this automation so that it would call me via Twilio when the alarm started, but I could not manage to trigger it. This also goes for yale sync alarm. How do you think I can find a solution to this? Does anyone know the problem?
Does the notification itself work? Have you tried clicking on the 3 dots next to the notifcation command an executing the action? If this works, the problem must be in the “when” block.
If you click edit in YAML and paste the code as preformatted text (</> button ) it is a lot easier for people to see what your automation actually is containing.
If your integration never registers the “smoke detected” event, it is an integration problem and not a problem with the automation. You should ask for support on the Github repository of the integration.
Yes, I opened the github page but there is no community page. I wrote to Tuya’s e-mail address. I hope they write an answer and help. However, I think many devices connected via tuya experience similar problems. I think it is the healthiest way to connect Zigbee devices via mqtt. I haven’t found a solution yet. I reinstalled the integration but it still didn’t work.
