❄️ HA Snowflakes Card — animated snowflakes overlay for your dashboard
I built a small Lovelace custom card that renders animated falling snowflakes as a full-screen overlay on your dashboard. Every snowflake is individually defined with its own size, speed, drift, rotation, and opacity — no two fall exactly the same way.
Why not just use the built-in Winter Mode?
Home Assistant 2025.12 introduced Winter Mode in Labs, and it's a nice touch. But it has some limitations that pushed me to build this:
Winter Mode (Labs) HA Snowflakes Card
Color White only Any color or hex
Per-dashboard control :cross_mark: :white_check_mark:
Automation / conditional :cross_mark: :white_check_mark: via conditional card
Works for all users :warning: Admin only (known bug) :white_check_mark:
Snowflake count Fixed Configurable
Multiple layers :cross_mark: :white_check_mark:
Installation
Or add Xornop/ha-snowflakes-card manually as a custom repository in HACS under Frontend.
Usage
type: custom:snowflakes-card
color: "#ffffff"
All options:
Option Default Description
color #ffffff Any CSS color or hex value
count 50 Number of snowflakes (max 50)
opacity 1 Global opacity multiplier (0–1)
Examples
Wrap it in a conditional card to automate it:
type: conditional
conditions:
  - entity: input_boolean.christmasmode
    state: "on"
card:
  color: "#ffffff"
Or use two instances for a layered effect — white flakes at night, green during the day:
type: grid
cards:
  - type: conditional
    conditions:
        state: "on"
      - condition: state
        entity: sun.sun
        state: below_horizon
    card:
      color: "#ffffff"
  - type: conditional
    conditions:
        state: "on"
      - condition: state
        entity: sun.sun
        state: above_horizon
    card:
      color: "#507828"
      opacity: 0.7
Feedback and PRs welcome — repo is at GitHub - Xornop/ha-snowflakes-card: An invisible card to get better snowflakes on your dashboard. · GitHub
Its currentvy very hot outside. Maybe snowflakes help to feela little cooler :wink:
