HA Stopping using Modbus Device
Hello guys!
I do not know if this is the best channel to post this but I would like to register a situation that occurred with my HA:
I have in my network three devices that have the modbus tcp protocol (Siemens, Rockwell and HI Technology and Arduino).
Since I could not connect all the devices at the same time in the Home, I configured each device separately.
What I observed is that I can read and write values on all devices, but when I connect the Siemens device (S7-1200) and the Arduino (Mega with Shield Ethernet) the HA simply goes into Stop mode, it stops.
Via SSH and type the command to restart appears the message ‘service not running’.
I use raspbian with HA.
If someone has something that can be done or parameter that can be used.
I am using the version 0.64.3
