HA stops reporting Kodi status after a few hours
Hi
I’m currently using HA version 0.57.2 and since 0.53 HA stops reporting Kodi status (intermittent). If I restart HA it will show the status for a few hours but after a while it stops. By then I need to restart HA, and it will work a few hours. I cannot see any errors related to Kodi in the log file.
Has anyone had similar issues or might have a solution? I need the status to be able to turn off lights when playing movies or series.
My configuration
media_player:
  - platform: kodi
    host: 192.168.1.72
    port: 8080
    username: kodi
    password: kodi
Thanks in advance.
Br Qxlkdr
Anyone with the same issue or might know what it is?
Br Qxlkdr
I’m running Python 3.5, could it be that I need to update to 3.6 in my Virtual Environment?
Br Qxlkdr
@Qxlkdr,
Been having the same issue for a while now, actually on mine Kodi no longer shows up at all even for a few minutes unlike yours. Still no fix yet :frowning:
Regards
Hoping HA team finds a fix soon…
I believe this is still an issue. The status is reliable for several hours then no longer updates.
Yup, I have 3 CoreElec boxes (ODROID C2’s) running the latest version of kodi (controlled by 3x Harmony Hub, one with receiver + speakers, one with just external speakers), this whole thing works stable (i.e. you can control each room/area with each of the 3 media_player entities + physical harmony remotes.)
The only thing that keeps happening is that one or more of my kodi entities stops updating its state. And a restart of home-assistant fixes it. (So I don’t think it’s an issue on kodi’s side.)
Change your kodi webserver to port 80. This fixed it for me. Note that you will need to run kodi as a privileged account to start the webserver on port 80.
I’m running Kodi on a Fire Stick and I won’t allow me to use port 80. Thanks for the tip though.
