HA newbie here, stuck at installation. Intense googling did not help.
Goal: install HA with add-ons (MTTQ is a must, more to follow) on an old PC acting as a home server to run home smart gadgets.
PC: Intel Core2 Quad CPU Q8200, 8GB RAM, 6T raid1 hdd, Ubuntu 20.04.5 server, headless, dns, dhcp, smb, nfs, …
Context: as a newbie I have missed the difference between core and supervised and first installed core edition (as docker container). No problems at all, except MQTT was not available. Scratched core edition and followed guide on [GitHub - home-assistant/supervised-installer: Installer for a generic Linux system]. Failed to get localhost:8123 preparation page. Started digging and messing arround.
What looks good:
- Ubuntu is updated and upgraded
- dependencies are met (apparmor, jq, wget, curl, udisks2, libglib2.0-bin, network-manager, dbus, systemd-journal-remote)
- docker platform looks good (installed and tested during successful ‘ha-core’ attempt)
- os-agent replays to gdbus introspect (‘node /io/hass/os { interface org.freedesktop.DBus.Introspectable { methods:’…)
- downloaded .deb from Release 1.2.2 · home-assistant/supervised-installer · GitHub
/download/homeassistant-supervised.deb - dpkg -i homeassistant-supervised.deb played nicely, and finished with:
[info] Within a few minutes you will be able to reach Home Assistant at:
[info] http://homeassistant.local:8123 or using the IP address of your
[info] machine: http://192.168.0.254:8123
- ha docker container was downloaded:
root@bielak:/fs/home/daemons/home_assistant# docker container ls -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
218325c783c6 ghcr.io/home-assistant/amd64-hassio-supervisor:latest "/init" About an hour ago Up About an hour hassio_supervisor
ef68098f6882 ubuntu "bash" 6 days ago Exited (0) 2 hours ago hungry_swirles
bfce78fd6db6 hello-world "/hello" 6 days ago Exited (0) 6 days ago quirky_banzai
- image is there:
root@bielak:/fs/home/daemons/home_assistant# docker image ls -a
REPOSITORY TAG IMAGE ID CREATED SIZE
ghcr.io/home-assistant/amd64-hassio-supervisor latest b1f30bcec501 25 hours ago 335MB
ghcr.io/home-assistant/home-assistant stable dc6d95cb9337 6 days ago 1.47GB
ubuntu latest 2dc39ba059dc 2 weeks ago 77.8MB
hello-world latest feb5d9fea6a5 11 months ago 13.3kB
What looks bad:
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[31m22-09-18 14:28:36 ERROR (MainThread) [supervisor.utils.dbus] Could not get introspection data after 3 attempts#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[33m22-09-18 14:28:36 WARNING (MainThread) [supervisor.dbus.agent] Can't connect to OS-Agent#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[33m22-09-18 14:28:36 WARNING (MainThread) [supervisor.dbus.systemd] Can't connect to systemd#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[33m22-09-18 14:28:36 WARNING (MainThread) [supervisor.dbus.logind] Can't connect to systemd-logind#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[33m22-09-18 14:28:36 WARNING (MainThread) [supervisor.dbus.hostname] Can't connect to systemd-hostname#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[33m22-09-18 14:28:36 WARNING (MainThread) [supervisor.dbus.timedate] Can't connect to systemd-timedate#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[33m22-09-18 14:28:36 WARNING (MainThread) [supervisor.dbus.network] Can't connect to Network Manager#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[33m22-09-18 14:28:36 WARNING (MainThread) [supervisor.dbus.rauc] Can't connect to rauc#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[33m22-09-18 14:28:36 WARNING (MainThread) [supervisor.dbus.resolved] Can't connect to systemd-resolved.#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[32m22-09-18 14:28:36 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[32m22-09-18 14:28:36 INFO (MainThread) [supervisor.jobs] 'NetworkManager.load' blocked from execution, host Network Manager not available#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[32m22-09-18 14:28:36 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}#033[0m
Sep 18 16:28:36 bielak 218325c783c6[14642]: #033[33m22-09-18 14:28:36 WARNING (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on host#033[0m
My thoughts:
- perhaps previous installation of ha-core messed something? some (mis)configuration left? however ha-supervisor runs in its own docker container and should be isolated…
- could the fact that I have disabled IPv6 in kernel give such strange effects? well, IPv4 works just fine. could IPv6 be a hard dependency? it was not for ha-core…
Would you please advice how to diagnose and finally solve the problem?
Should I provide syslog with installation? If so what is the preferred method to publish 413 lines of text (44kB)?
root@bielak:/fs/home/daemons/home_assistant# docker container inspect hassio_supervisor
"Id": "218325c783c64c4bad6fb8210a800e21a5a4f0016950aedd2beea04926573b51",
"Created": "2022-09-18T14:27:58.480991522Z",
"Path": "/init",
"Args": [],
"State": {
"Status": "running",
"Running": true,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 15260,
"ExitCode": 0,
"Error": "",
"StartedAt": "2022-09-18T14:28:00.64681336Z",
"FinishedAt": "0001-01-01T00:00:00Z"
"Image": "sha256:b1f30bcec5013d77840cd53f864b0642a8327eea1db8e740974f796e7c5a9f7d",
"ResolvConfPath": "/var/lib/docker/containers/218325c783c64c4bad6fb8210a800e21a5a4f0016950aedd2beea04926573b51/resolv.conf",
"HostnamePath": "/var/lib/docker/containers/218325c783c64c4bad6fb8210a800e21a5a4f0016950aedd2beea04926573b51/hostname",
"HostsPath": "/var/lib/docker/containers/218325c783c64c4bad6fb8210a800e21a5a4f0016950aedd2beea04926573b51/hosts",
"LogPath": "",
"Name": "/hassio_supervisor",
"RestartCount": 0,
"Driver": "overlay2",
"Platform": "linux",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "unconfined",
"ExecIDs": null,
"HostConfig": {
"Binds": [
"/run/supervisor:/run/os:rw",
"/run/udev:/run/udev:ro",
"/etc/machine-id:/etc/machine-id:ro",
"/usr/share/hassio:/data:rw",
"/run/docker.sock:/run/docker.sock:rw",
"/run/dbus:/run/dbus:ro"
"ContainerIDFile": "",
"LogConfig": {
"Type": "journald",
"Config": {}
"NetworkMode": "default",
"PortBindings": {},
"RestartPolicy": {
"Name": "no",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": null,
"CapAdd": null,
"CapDrop": null,
"CgroupnsMode": "host",
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "private",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"Privileged": true,
"PublishAllPorts": false,
"ReadonlyRootfs": false,
"SecurityOpt": [
"apparmor=hassio-supervisor",
"label=disable"
"UTSMode": "",
"UsernsMode": "",
"ShmSize": 67108864,
"Runtime": "runc",
"ConsoleSize": [
0,
0
"Isolation": "",
"CpuShares": 0,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "",
"BlkioWeight": 0,
"BlkioWeightDevice": [],
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": [],
"DeviceCgroupRules": null,
"DeviceRequests": null,
"KernelMemory": 0,
"KernelMemoryTCP": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"OomKillDisable": false,
"PidsLimit": null,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0,
"MaskedPaths": null,
"ReadonlyPaths": null
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/d870810efb3595b071d8f256bf7156ab641b7b4973b24f84e81c3a2c225163aa-init/diff:/var/lib/docker/overlay2/0b3a68946af8c8aa1eec166b0b36406d35a441bd407d1a69dd754a4fca7beae9/diff:/var/lib/docker/overlay2/c226aff003712a1f2ae34f9d1c0e04541b0a9fd5c8edf1d564453ed17e67ac21/diff:/var/lib/docker/overlay2/325f02ba7c9ca4fd464e2c045b3c91d802360d4a6333073d934543800d864920/diff:/var/lib/docker/overlay2/2c76e88ee506570e84c7f9e81bd95c4b9ebf2a00c01df7b93fbeeb345a3654a5/diff:/var/lib/docker/overlay2/88d01f5e017cc3cd2f77f4d984034f2425752186ff60f694ffdd80ba18f2fd0f/diff:/var/lib/docker/overlay2/31da4a2eb94d551ed1f99a2abd95a070088961680d77698f2d7d082636d27790/diff:/var/lib/docker/overlay2/facad772ad857ac15fe25af1017774b766a1799fd872789f81e6268cb0bfa6af/diff:/var/lib/docker/overlay2/bf32d5dd70493d2e38a4f64ee38b58ae13e42f066bec48b872b68b29ddbc8bff/diff:/var/lib/docker/overlay2/c8c4a18d703e0fdbbb4a9339d83e9795c2eb821e7120e515db1e1702d68cc54f/diff:/var/lib/docker/overlay2/fb849e12b3b2ba36587216555f7ac091d7c99d359691b8db812ab4426100b526/diff:/var/lib/docker/overlay2/89b898ba46c5763830a88105e3455cdc6f59bb9793d922ba8ea4747b48529851/diff:/var/lib/docker/overlay2/5138bf16f772fd645be54e4590dab2a6d3ad2338e525bbbe2fa80055b5a5a1a2/diff:/var/lib/docker/overlay2/2e9c31c5fdca797e258b07be286c1a6abc4cf0b20274e25c7095015917359d9a/diff:/var/lib/docker/overlay2/3f0820b0d393b17882fa890085f792b2ee2adb43af0daee2ab696ae6849c985e/diff",
"MergedDir": "/var/lib/docker/overlay2/d870810efb3595b071d8f256bf7156ab641b7b4973b24f84e81c3a2c225163aa/merged",
"UpperDir": "/var/lib/docker/overlay2/d870810efb3595b071d8f256bf7156ab641b7b4973b24f84e81c3a2c225163aa/diff",
"WorkDir": "/var/lib/docker/overlay2/d870810efb3595b071d8f256bf7156ab641b7b4973b24f84e81c3a2c225163aa/work"
"Name": "overlay2"
"Mounts": [
"Type": "bind",
"Source": "/run/dbus",
"Destination": "/run/dbus",
"Mode": "ro",
"RW": false,
"Propagation": "rprivate"
"Type": "bind",
"Source": "/run/supervisor",
"Destination": "/run/os",
"Mode": "rw",
"RW": true,
"Type": "bind",
"Source": "/run/udev",
"Destination": "/run/udev",
"Mode": "ro",
"RW": false,
"Type": "bind",
"Source": "/etc/machine-id",
"Destination": "/etc/machine-id",
"Mode": "ro",
"RW": false,
"Type": "bind",
"Source": "/usr/share/hassio",
"Destination": "/data",
"Mode": "rw",
"RW": true,
"Type": "bind",
"Source": "/run/docker.sock",
"Destination": "/run/docker.sock",
"Mode": "rw",
"RW": true,
"Config": {
"Hostname": "218325c783c6",
"Domainname": "",
"User": "",
"AttachStdin": false,
"AttachStdout": true,
"AttachStderr": true,
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"SUPERVISOR_SHARE=/usr/share/hassio",
"SUPERVISOR_NAME=hassio_supervisor",
"SUPERVISOR_MACHINE=qemux86-64",
"PATH=/usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"LANG=C.UTF-8",
"S6_BEHAVIOUR_IF_STAGE2_FAILS=2",
"S6_CMD_WAIT_FOR_SERVICES_MAXTIME=0",
"S6_CMD_WAIT_FOR_SERVICES=1",
"S6_SERVICES_GRACETIME=10000",
"SUPERVISOR_API=http://localhost"
"Cmd": null,
"Image": "ghcr.io/home-assistant/amd64-hassio-supervisor:latest",
"Volumes": null,
"WorkingDir": "/",
"Entrypoint": [
"/init"
"OnBuild": null,
"Labels": {
"io.hass.arch": "amd64",
"io.hass.base.arch": "amd64",
"io.hass.base.image": "homeassistant/amd64-base:3.16",
"io.hass.base.name": "python",
"io.hass.base.version": "2022.08.0",
"io.hass.type": "supervisor",
"io.hass.version": "2022.09.dev1703",
"org.opencontainers.image.authors": "The Home Assistant Authors",
"org.opencontainers.image.created": "2022-09-17 14:26:03+00:00",
"org.opencontainers.image.description": "Container-based system for managing Home Assistant Core installation",
"org.opencontainers.image.documentation": "https://www.home-assistant.io/docs/",
"org.opencontainers.image.licenses": "Apache License 2.0",
"org.opencontainers.image.source": "https://github.com/home-assistant/supervisor",
"org.opencontainers.image.title": "Home Assistant Supervisor",
"org.opencontainers.image.url": "https://www.home-assistant.io/",
"org.opencontainers.image.version": "2022.09.dev1703"
"NetworkSettings": {
"Bridge": "",
"SandboxID": "1c832f80958e7115a57713207f8c05f1afe27c5f62227286a170f4ce426cd68c",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {},
"SandboxKey": "/var/run/docker/netns/1c832f80958e",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "66ffd8c91c5a0cb6f5db6fde529dae83f90dafcbea6ed30a222299ff98281fd7",
"Gateway": "172.17.0.1",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "172.17.0.2",
"IPPrefixLen": 16,
"IPv6Gateway": "",
"MacAddress": "02:42:ac:11:00:02",
"Networks": {
"bridge": {
"IPAMConfig": null,
"Links": null,
"Aliases": null,
"NetworkID": "7953d42d0add51332c6a3c3e80707d8aef03cfca2b9ef9e88f79f2dfe25c30f2",
"IPPrefixLen": 16,
"IPv6Gateway": "",
"DriverOpts": null
"hassio": {
"IPAMConfig": {
"IPv4Address": "172.30.32.2"
"Links": null,
"Aliases": [
"supervisor",
"218325c783c6"
"NetworkID": "430c52971dc9e08494a60d69aabf5aab5169356f1775830bc1b99b384e48ab66",
"EndpointID": "6a84bcd88cba3bfb906e80f87efadd2b3dab5c184f3d12d8c8fffcd66cb66654",
"Gateway": "172.30.32.1",
"IPAddress": "172.30.32.2",
"IPPrefixLen": 23,
"IPv6Gateway": "",
"MacAddress": "02:42:ac:1e:20:02",
"DriverOpts": null
