I know this may be another post about this… I tried searching and I couldn’t find something that matched up.
I’m new to HA and understanding the yaml setup and where to put what and how and what-not is all new me… and I’ve tried to read some of the white papers, but it’s just not lining up to me.
I have a number of Air Quality sensors from Govee that I just setup. I just setup the Gen3 Nest to HA today (what a pain, was really hoping for offline only).
what I wanted to do and what I read I could do it turn the Nest Fan on and off based on triggers,
I’m having a few issues with understanding this.
when I look at examples of Nest Fan Control I’m finding this
Post: Nest Fan Control - #4 by brg468
Example:
sequence:
- entity_id: climate.thermostat
service: climate.set_fan_mode
fan_mode: ‘on’ - delay:
minutes: 30 - entity_id: climate.thermostat
fan_mode: ‘off’
and also this
Post: Nest Fan and Temperature Control Stopped Working
Example:
- service: climate.set_fan_mode
fan_mode: "on"
entity_id:
- climate.firstfloor
when I try to setup the automation using the GUI, I don’t have a fan mode, I can just change to the Heat/Cold/Eco modes.
when I look at the yaml method that’s created it looks nothing like the examples I see online…
I see device ID’s where all examples don’t, then Entity_id’s are text based where mine isn’t
device_id: ***********************************312c1
domain: climate
entity_id: ****************************************317
type: set_hvac_mode
metadata:
secondary: false
hvac_mode: “off”
continue_on_error: true
I can program in a number of industrial languages and when I learn a new one I use what I know to establish a relationship between what I know and what I’m learning… that’s not working here and what I see online and what I’m seeing locally is also too different. I can’t base that relationship.
Is there somewhere I can’t go to to help figure this out? the White papers and RTFM is not working out for me.
thanks in advance
Vin
