Here is my HA log:
2021-07-26 17:22:44 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tapo_p100_control which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-26 17:22:44 ERROR (SyncWorker_0) [homeassistant.loader] The custom integration 'tapo_p100_control' does not have a valid version key (None) in the manifest file and was blocked from loading. See https://developers.home-assistant.io/blog/2021/01/29/custom-integration-changes#versions for more details
2021-07-26 17:22:46 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2021-07-26 17:22:54 WARNING (MainThread) [homeassistant.components.hive] The 'hive' option near /config/configuration.yaml:0 is deprecated, please remove it from your configuration
2021-07-26 17:22:55 WARNING (MainThread) [homeassistant.components.broadlink.switch] The 'host' option near /config/configuration.yaml:242 is deprecated, please remove it from your configuration
2021-07-26 17:22:55 WARNING (MainThread) [homeassistant.components.broadlink.switch] The 'host' option near /config/configuration.yaml:275 is deprecated, please remove it from your configuration
2021-07-26 17:22:55 WARNING (MainThread) [homeassistant.components.squeezebox.media_player] The 'host' option near /config/configuration.yaml:150 is deprecated, please remove it from your configuration
2021-07-26 17:23:00 ERROR (MainThread) [homeassistant.components.updater] Error requesting Home Assistant update data: Cannot connect to host www.home-assistant.io:443 ssl:default [Try again]
2021-07-26 17:23:00 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for hive integration could not authenticate
2021-07-26 17:23:00 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2021-07-26 17:23:01 ERROR (Thread-4) [pychromecast.discovery] Unhandled exception in worker thread
File "/usr/local/lib/python3.9/site-packages/pychromecast/discovery.py", line 252, in run
self._poll_hosts()
File "/usr/local/lib/python3.9/site-packages/pychromecast/discovery.py", line 268, in _poll_hosts
device_status = get_device_status(host, timeout=4, context=self._context)
File "/usr/local/lib/python3.9/site-packages/pychromecast/dial.py", line 109, in get_device_status
status = _get_status(
File "/usr/local/lib/python3.9/site-packages/pychromecast/dial.py", line 88, in _get_status
with urllib.request.urlopen(req, timeout=timeout, context=context) as response:
File "/usr/local/lib/python3.9/urllib/request.py", line 214, in urlopen
return opener.open(url, data, timeout)
File "/usr/local/lib/python3.9/urllib/request.py", line 517, in open
response = self._open(req, data)
File "/usr/local/lib/python3.9/urllib/request.py", line 534, in _open
result = self._call_chain(self.handle_open, protocol, protocol +
File "/usr/local/lib/python3.9/urllib/request.py", line 494, in _call_chain
result = func(*args)
File "/usr/local/lib/python3.9/urllib/request.py", line 1389, in https_open
return self.do_open(http.client.HTTPSConnection, req,
File "/usr/local/lib/python3.9/urllib/request.py", line 1315, in do_open
h = http_class(host, timeout=req.timeout, **http_conn_args)
File "/usr/local/lib/python3.9/http/client.py", line 1380, in __init__
super(HTTPSConnection, self).__init__(host, port, timeout,
File "/usr/local/lib/python3.9/http/client.py", line 832, in __init__
self._validate_host(self.host)
File "/usr/local/lib/python3.9/http/client.py", line 1206, in _validate_host
raise InvalidURL(f"URL can't contain control characters. {host!r} "
http.client.InvalidURL: URL can't contain control characters. 'Lounge TV' (found at least ' ')
2021-07-26 17:23:01 ERROR (Thread-4) [root] Uncaught thread exception
File "/usr/local/lib/python3.9/threading.py", line 954, in _bootstrap_inner
self.run()
self._poll_hosts()
2021-07-26 17:23:04 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Broadlink_Lounge' for broadlink integration not ready yet: [Errno -4000] Network timeout; Retrying in background
2021-07-26 17:23:04 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Broadlink_Kitchen' for broadlink integration not ready yet: [Errno -4000] Network timeout; Retrying in background
2021-07-26 17:23:04 WARNING (MainThread) [homeassistant.components.broadlink.switch] Your configuration for the switch platform is deprecated. Please refer to the Broadlink documentation to catch up
2021-07-26 17:23:05 ERROR (MainThread) [homeassistant.components.ezviz] Unable to connect to Ezviz service: A Invalid URL or Proxy error occured
2021-07-26 17:23:05 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for ezviz integration not ready yet: A Invalid URL or Proxy error occured; Retrying in background
2021-07-26 17:23:28 WARNING (MainThread) [homeassistant.components.media_player] Updating squeezebox media_player took longer than the scheduled update interval 0:00:10
2021-07-26 17:23:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.kitchen is taking over 10 seconds
2021-07-26 17:23:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.bedroom is taking over 10 seconds
2021-07-26 17:23:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.lounge_tv is taking over 10 seconds
2021-07-26 17:23:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.shield_2 is taking over 10 seconds
2021-07-26 17:23:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.lounge_speaker_4 is taking over 10 seconds
2021-07-26 17:23:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.kitchen_speaker is taking over 10 seconds
2021-07-26 17:23:28 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.study is taking over 10 seconds
2021-07-26 17:23:28 ERROR (MainThread) [pysqueezebox.server] Failed communicating with LMS: <class 'asyncio.exceptions.TimeoutError'>
2021-07-26 17:23:40 WARNING (Thread-6) [pychromecast.socket_client] [Lounge speaker(192.168.1.45):8009] Heartbeat timeout, resetting connection
2021-07-26 17:23:52 ERROR (Thread-7) [pychromecast.socket_client] [SHIELD(192.168.1.217):8009] Failed to connect to service ServiceInfo(type='mdns', data='SHIELD-Android-TV-92534629569444c4c2f8a43d471b1c1f._googlecast._tcp.local.'), retrying in 5.0s
2021-07-26 17:23:55 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: asuswrt, device_tracker, owntracks
2021-07-26 17:24:07 WARNING (Thread-9) [pychromecast.socket_client] [Google Kitchen(192.168.1.85):8009] Heartbeat timeout, resetting connection
2021-07-26 17:24:09 ERROR (Thread-8) [pychromecast.socket_client] [Lounge TV(192.168.1.74):8009] Failed to connect to service ServiceInfo(type='mdns', data='Chromecast-cc0357aa45d05e3de942969975197971._googlecast._tcp.local.'), retrying in 5.0s
2021-07-26 17:24:10 ERROR (Thread-6) [pychromecast.socket_client] [Lounge speaker(192.168.1.45):8009] Failed to connect to service ServiceInfo(type='mdns', data='Google-Home-203b884a84f1ef7866f8fa1770337311._googlecast._tcp.local.'), retrying in 5.0s
2021-07-26 17:24:18 ERROR (MainThread) [pysqueezebox.server] Failed communicating with LMS: <class 'asyncio.exceptions.TimeoutError'>
2021-07-26 17:24:19 ERROR (Thread-10) [pychromecast.socket_client] [Study speaker(192.168.1.88):8009] Failed to connect to service ServiceInfo(type='mdns', data='Google-Home-Mini-44edfa3e5bcec65165af31d4361012b8._googlecast._tcp.local.'), retrying in 5.0s
2021-07-26 17:24:20 WARNING (Thread-7) [pychromecast.socket_client] [SHIELD(192.168.1.217):8009] Heartbeat timeout, resetting connection
2021-07-26 17:24:37 ERROR (Thread-9) [pychromecast.socket_client] [Google Kitchen(192.168.1.85):8009] Failed to connect to service ServiceInfo(type='mdns', data='Google-Home-Mini-dedaf1babd473ca5603cd0b61c49051d._googlecast._tcp.local.'), retrying in 5.0s
2021-07-26 17:24:38 WARNING (Thread-8) [pychromecast.socket_client] [Lounge TV(192.168.1.74):8009] Heartbeat timeout, resetting connection
2021-07-26 17:24:48 WARNING (Thread-10) [pychromecast.socket_client] [Study speaker(192.168.1.88):8009] Heartbeat timeout, resetting connection
2021-07-26 17:24:50 ERROR (Thread-7) [pychromecast.socket_client] [SHIELD(192.168.1.217):8009] Failed to connect to service ServiceInfo(type='mdns', data='SHIELD-Android-TV-92534629569444c4c2f8a43d471b1c1f._googlecast._tcp.local.'), retrying in 5.0s
2021-07-26 17:24:55 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: asuswrt, device_tracker, owntracks
2021-07-26 17:25:04 WARNING (MainThread) [homeassistant.config_entries] Config entry '192.168.1.1' for asuswrt integration not ready yet: [Errno 110] Connect call failed ('192.168.1.1', 22); Retrying in background
2021-07-26 17:25:08 ERROR (Thread-8) [pychromecast.socket_client] [Lounge TV(192.168.1.74):8009] Failed to connect to service ServiceInfo(type='mdns', data='Chromecast-cc0357aa45d05e3de942969975197971._googlecast._tcp.local.'), retrying in 5.0s
2021-07-26 17:25:18 ERROR (Thread-10) [pychromecast.socket_client] [Study speaker(192.168.1.88):8009] Failed to connect to service ServiceInfo(type='mdns', data='Google-Home-Mini-44edfa3e5bcec65165af31d4361012b8._googlecast._tcp.local.'), retrying in 5.0s
2021-07-26 17:25:28 ERROR (MainThread) [pysqueezebox.server] Failed communicating with LMS: <class 'asyncio.exceptions.TimeoutError'>
2021-07-26 17:25:55 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: device_tracker, owntracks
2021-07-26 17:26:55 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: device_tracker, owntracks
2021-07-26 17:27:55 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: device_tracker, owntracks
2021-07-26 17:28:01 ERROR (MainThread) [homeassistant.setup] Setup of device_tracker is taking longer than 300 seconds. Startup will proceed without waiting any longer
2021-07-26 17:28:01 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 153, in async_init
flow, result = await task
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 179, in _async_init
result = await self._async_handle_step(flow, flow.init_step, data, init_done)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 260, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/owntracks/config_flow.py", line 56, in async_step_import
webhook_id, _webhook_url, cloudhook = await self._get_webhook_id()
File "/usr/src/homeassistant/homeassistant/components/owntracks/config_flow.py", line 76, in _get_webhook_id
webhook_url = self.hass.components.webhook.async_generate_url(webhook_id)
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 60, in async_generate_url
get_url(hass, prefer_external=True, allow_cloud=False),
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 83, in get_url
request_host = _get_request_host()
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 123, in _get_request_host
raise NoURLAvailableError
homeassistant.helpers.network.NoURLAvailableError
File "/usr/src/homeassistant/homeassistant/components/hive/config_flow.py", line 120, in async_step_reauth
return await self.async_step_user(data)
File "/usr/src/homeassistant/homeassistant/components/hive/config_flow.py", line 48, in async_step_user
self.tokens = await self.hive_auth.login()
File "/usr/local/lib/python3.9/site-packages/apyhiveapi/api/hive_auth_async.py", line 219, in login
await self.async_init()
File "/usr/local/lib/python3.9/site-packages/apyhiveapi/api/hive_auth_async.py", line 82, in async_init
self.__pool_id = self.data.get("UPID")
AttributeError: 'NoneType' object has no attribute 'get'
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Database is about to upgrade. Schema version: 5
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding columns context_id, context_user_id to table events. Note: this can take several minutes on large databases and slow computers. Please be patient!
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Column context_id already exists on events, continuing
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Column context_user_id already exists on events, continuing
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding index `ix_events_context_id` to database. Note: this can take several minutes on large databases and slow computers. Please be patient!
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Index ix_events_context_id already exists on events, continuing
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding index `ix_events_context_user_id` to database. Note: this can take several minutes on large databases and slow computers. Please be patient!
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Index ix_events_context_user_id already exists on events, continuing
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding columns context_id, context_user_id to table states. Note: this can take several minutes on large databases and slow computers. Please be patient!
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Column context_id already exists on states, continuing
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Column context_user_id already exists on states, continuing
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding columns context_parent_id to table events. Note: this can take several minutes on large databases and slow computers. Please be patient!
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Column context_parent_id already exists on events, continuing
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding columns old_state_id to table states. Note: this can take several minutes on large databases and slow computers. Please be patient!
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Column old_state_id already exists on states, continuing
2021-07-26 17:28:01 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding index `ix_events_context_parent_id` to database. Note: this can take several minutes on large databases and slow computers. Please be patient!
2021-07-26 17:28:01 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry 192.168.1.1 for asuswrt
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 293, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/asuswrt/__init__.py", line 123, in async_setup_entry
await router.setup()
File "/usr/src/homeassistant/homeassistant/components/asuswrt/router.py", line 235, in setup
await self._api.connection.async_connect()
File "/usr/local/lib/python3.9/site-packages/aioasuswrt/connection.py", line 78, in async_connect
self._client = await asyncssh.connect(self._host, **kwargs)
File "/usr/local/lib/python3.9/site-packages/asyncssh/connection.py", line 6803, in connect
return await _connect(options, loop, flags, conn_factory,
File "/usr/local/lib/python3.9/site-packages/asyncssh/connection.py", line 303, in _connect
await conn.wait_established()
File "/usr/local/lib/python3.9/site-packages/asyncssh/connection.py", line 2243, in wait_established
await self._waiter
asyncssh.misc.ConnectionLost: Connection lost
2021-07-26 17:37:48 WARNING (Recorder) [homeassistant.components.recorder.migration] Failed to drop index ix_states_context_id from table states. Schema Migration will continue; this is not a critical operation
2021-07-26 17:37:48 WARNING (Recorder) [homeassistant.components.recorder.migration] Failed to drop index ix_states_context_user_id from table states. Schema Migration will continue; this is not a critical operation
2021-07-26 17:37:48 WARNING (Recorder) [homeassistant.components.recorder.migration] Failed to drop index ix_states_entity_id from table states. Schema Migration will continue; this is not a critical operation
2021-07-26 17:37:48 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding index `ix_events_event_type_time_fired` to database. Note: this can take several minutes on large databases and slow computers. Please be patient!
