Is unable to check for updates for core, e.g. I was running 2025.8.0 and it did not show me there was an update to .1
This started happening when I changed ISPs and router hw. I had to change the DNS server in the config page to be able to force update via the terminal as the Update page in the UI did not give any error or message when I hit the check for update button, but the terminal cmd line did say that the update endpoint was unreachable (very weird but OK).
Currently the only way for me to update HA is on the cmd line and EXPLICITLY passing on the version number, if I just use āha core updateā it doesnāt see the update either.
I do not get any error messages in the syslog that I can see.
If anyone is interested in debugging this let me know what I can do as this most certainly is not the happy flow
Strange thing is that the DNS server I configged for IPv4 in the network page is 212.71.0.33 which is not the one HA seems to be using looking at the log
Read the supervisor log if you see āsupervisor no internetā that is whatās causing the failure of update detection. Troubleshoot THAT. (you almost certainly have either a time sync or DNS issue if you saw this in conjunction with an ISP change happening)
2025-08-12 18:12:36.242 WARNING (MainThread) [supervisor.jobs] 'GitRepo.pull' blocked from execution, no supervisor internet connection
2025-08-12 18:12:36.243 WARNING (MainThread) [supervisor.jobs] 'GitRepo.pull' blocked from execution, no supervisor internet connection
2025-08-12 18:12:42.243 WARNING (MainThread) [supervisor.jobs] 'GitRepo.pull' blocked from execution, no supervisor internet connection
2025-08-12 18:12:42.244 ERROR (MainThread) [supervisor.store] Could not reload repository 982ee2c4 due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")
2025-08-12 18:12:42.244 ERROR (MainThread) [supervisor.store] Could not reload repository 5c53de3b due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")
2025-08-12 18:12:42.244 ERROR (MainThread) [supervisor.store] Could not reload repository core due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")
2025-08-12 18:12:42.244 ERROR (MainThread) [supervisor.store] Could not reload repository a0d7b954 due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")
2025-08-12 18:12:42.244 ERROR (MainThread) [supervisor.store] Could not reload repository d5369777 due to StoreJobError("'GitRepo.pull' blocked from execution, no supervisor internet connection")
Looks like it. As updated in my original post, I have no clue where HA is getting that dns-server=āudp:195.130.130.2:53ā from though
Ok then that means you donāt have your own internal DNS there⦠See what adding 1.1.1.1 as first DNS (you can drop your or your ISP as secondary or tertiary or leave it out entirely )
Have you restarted the HA host (not just HA core).
Many of the network stuff run in the OS and core just relay to the OS, so if the OS is at fault, then restart core will have no effect.
