Since this morning HA is offline and I cannot access it via web of android app. I get the error " Unable to connect - failed to perform SSL handshake". I have an active subsciption to nabu casa. First thing I tried was to reboot HA - without any result. Also via the local address 10.0.0.101:8123 no response. Via http://10.0.0.101:4357 i could view the HA Observer Page and below the result.
Any advice how to get back in my HA, and start this thing?
`Home Assistant observer
Supervisor: Disconnected
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[02:02:20] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[02:02:20] INFO: Starting local supervisor watchdog...
2025-03-18 02:02:23.176 INFO (MainThread) [__main__] Initializing Supervisor setup
2025-03-18 02:02:23.345 INFO (MainThread) [supervisor.coresys] Setting up coresys for machine: generic-x86-64
2025-03-18 03:02:23.365 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2025.03.3
2025-03-18 03:02:23.365 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2025-03-18 03:02:23.615 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2025-03-18 03:02:23.624 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-03-18 03:02:23.626 INFO (MainThread) [__main__] Setting up Supervisor
2025-03-18 03:02:23.786 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
[07:28:21] INFO: Using udev information from host
[07:28:22] INFO: Starting local supervisor watchdog...
2025-03-18 07:28:24.968 INFO (MainThread) [__main__] Initializing Supervisor setup
2025-03-18 07:28:25.143 INFO (MainThread) [supervisor.coresys] Setting up coresys for machine: generic-x86-64
2025-03-18 08:28:25.164 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2025.03.3
2025-03-18 08:28:25.239 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2025-03-18 08:28:25.248 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-03-18 08:28:25.250 INFO (MainThread) [__main__] Setting up Supervisor
2025-03-18 08:28:25.410 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
[07:57:24] INFO: Using udev information from host
[07:57:24]`
