HA upgrade to 2025.5 and HACS issue
Hi there,
I’ve just updated my HA (running from RPI4) from version 2025.4 to 2025.5. The update resulted with an error in HACS (I’m running HACS 1.34.0).
Here is the error log:Error setting up entry for hacs:
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 749, in __async_setup_with_context
    result = await component.async_setup_entry(hass, self)
  File "/config/custom_components/hacs/__init__.py", line 246, in async_setup_entry
    setup_result = await async_initialize_integration(hass=hass, config_entry=config_entry)
  File "/config/custom_components/hacs/__init__.py", line 214, in async_initialize_integration
    await async_try_startup()
  File "/config/custom_components/hacs/__init__.py", line 201, in async_try_startup
    startup_result = await async_startup()
  File "/config/custom_components/hacs/__init__.py", line 170, in async_startup
    async_register_frontend(hass, hacs)
  File "/config/custom_components/hacs/frontend.py", line 68, in async_register_frontend
    hass.components.frontend.async_register_built_in_panel(
AttributeError: 'HomeAssistant' object has no attribute 'components'
Does anybody know how to fix this?
Many thanks in advance for your help!
Nicolas
Yes. Search the forum for how to update to HACS v2.
